Thread: Text Style
    2011-10
    Norfolk England
    38
    Default Text Style
    Hi
    I've not posted too much, always seem to find an answer using these forums, however I'm stumped.
    I have made a routine (see below) to create a text style, which in itself works fine.
    However, when the 'Text Style' dialog box is opened every time the new text style is highlighted it asks if it needs to be saved.
    Click 'Yes' but the 'Apply' button remains live when rehighlighted.
    Function IsomTextStyle()
    Dim IsoStyle As AcadTextStyle
    Dim name As String
    Dim Entry As AcadTextStyle
    Dim Found As Boolean
    Found = False
    For Each Entry In ThisDrawing.TextStyles
    If Entry.name = "Isom1" Then
    Found = True
    Exit For
    End If
    Next
    If Not (Found) Then
    Set IsoStyle = ThisDrawing.TextStyles.Add("Isom1")
    IsoStyle.fontFile = "romans.shx"
    IsoStyle.height = 0
    IsoStyle.Width = 1
    IsoStyle.ObliqueAngle = 5.76 '330 in radians, 30 = 0.524 rads
    Else
    End If
    ThisDrawing.ActiveTextStyle = IsoStyle
    End Function
    Is there a way to 'Apply' this change with VBA.
    If any one can help it will be appreciated
    Thx Once more in Advance
    It seems the problem is any backward slanting text eg -30!!!
    Even when changed in the Text Style Dialog box!
    Turlock, CA
    5,917
    Default Re: Text Style
    I was able to replicate your problem. It seems you found a bug. However, the problem is in AutoCAD not VBA. I can use the STYLE command to create a new style and set the oblique angle to any negative number and the error occurs when clicking on another style. Tested in 2018 and 2021.
    C:> ED WORKING....
    Turlock, CA
    5,917
    I also made some changes to your code. I improved setting the oblique factor and added a logic test for setting the active style. Note that if you click on the Go Advanced button, you can put your code in a code window to preserve formatting. Also, since your code doesn't return any object, it can be a sub rather than a function.
    Sub textsty()
        Dim name As String
        Found = False
        Found = True
        Exit For
        End If
        Next
        If Not (Found) Then
        Set IsoStyle = ThisDrawing.TextStyles.add("Isom1")
        IsoStyle.Height = 0
        IsoStyle.Width = 1
        IsoStyle.ObliqueAngle = DegToRad(-30)
        Else
        End If
        If Not ThisDrawing.ActiveTextStyle.name = "Isom1" Then ThisDrawing.ActiveTextStyle = IsoStyle
    End Sub
    Public Function DegToRad(Angle As Double)
        'convert degrees to radians
        DegToRad = ((Angle / 180) * PI)
    End Function
    Public Function PI() As Double
      PI = Atn(1) * 4
    End Function
    C:> ED WORKING....
    2011-10
    Norfolk England
    38
    Thx Ed
    Much Appreciated
    Never sure if it's me or 'Autocad'
    I have seen a lot of post relating to Isometric Text and Dimensions and thought it would be nice to have an automated IsomDimns and will post the humble routine I've created warts and all.
    Geoff
    Turlock, CA
    5,917
    BTW, I logged a bug with Autodesk. Now they are aware of it.
    C:> ED WORKING....
  1. Replies: 1
    Last Post: 2018-01-31, 02:45 PM
  2. 2014: Text Style not showing correct style??? architxt.shx
    By hcadang in forum AutoCAD General
    Last Post: 2016-12-15, 09:40 PM
  3. Replies: 1
    Last Post: 2016-09-19, 02:59 PM
  4. Isolate Selected Text Style or Dim Style
    Last Post: 2013-01-20, 05:10 AM
  5. Lock Text Height in Dimension Style when Text Style Height is Not 0
    Last Post: 2013-01-16, 04:55 AM
