Thread: 2021 Issues
    2015-10
    73
    Default 2021 Issues
    I recently updated to C3D 2021 and am having some issues. One issue I'm having, background masks are showing up as solid black rectangles. They were working fine in the already existing drawing that I first encountered this. I guess I can lose those until I figure that out.
    Next, every drawing I open new or old has defaulted to "Display Plot Styles" to off. Not a huge deal, right? Except when you have a dwg that has 200 sheets that you have to manually switch the display mode on for every sheet.
    Is there a global system variable for this? Anyone else having these problems with 2021?
    Help......
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: 2021 Issues
    Are the sheets using a predefined page setup? If so, you can enable that in the page setup manager for that page setup.
    Cairo - no, not Illinois
    5,069
    I you are not already using Named Pagesetups, this is the golden opportunity to get started and use them on all drawings. They are the best approach to hard copy that Autodesk ever came up with.
    2015-12
    Arizona
    2,478
    Import and apply a pagesetup, that has the settings you want enabled to those sheet layout
    2009-11
    5,719
    This may help:
    https://forums.augi.com/showthread.p...=1#post1219546
    Quote Originally Posted by BlackBox View Post
    <snip>
    Example
    (foreach layoutname (layoutlist)
      (vla-SetActivePageSetup layoutname “YourPageSetupName”)
    <snip>
    Computer Specs:
  1. 2021: Civil 3D 2021 - Pressure pipe runs
    By jmyers487961 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2020-08-21, 07:46 PM
  2. UNDO COMMAND AUTOLISP 2021
    By cadking2k5683822 in forum AutoLISP
    Last Post: 2020-07-27, 12:20 PM
  3. 2020: Electrical Features in Revit 2021
    By David Robison in forum Revit MEP - General
    Last Post: 2020-04-09, 06:39 AM
  4. 2020: 2021 - Drag Layout to SSM Not Working?
    By stusic in forum AutoCAD Sheet Set Manager
    Last Post: 2020-04-07, 11:40 PM
