Re: Revision Indexing
Summary: Tool that allows all drawings or (views) to be indexed or reported from a clouded revision.
Description: The idea I have is this. I create a revision in Revit then cloud the revision in a plan or section view. The title block records the revision, and that is great.
I have a vision of a tool that will cut thru a revision cloud and index the revision all views on and record the revision on other drawings in the Revit file. The advantage I see in a tool like this is to identify all drawings in a set that are affected by a single change to the model.
Product and Feature: Revit Architecture - Annotation Tools
Submitted By: Cwjohnson on 06/21/2021
- You may not post replies
- You may not edit your posts
Forum Rules
