Thread: Icons not moving to the top of custom flyout toolbars
    2001-01
    257
    Default Icons not moving to the top of custom flyout toolbars
    Hi All
    I have several custom toolbars with flyouts that are working perfectly in AutoCAD 2018. Since I have used the most recent versions of AutoCAD I have noticed a peculiar response from my toolbars. In the past, if I selected an icon somewhere down on a flyout it would automatically move it to the top. This was nice because I could rerun the command from the top icon. Since version 2020, I have noticed that AutoCAD doesn't do this anymore. Does anyone know if there is a system variable or switch in the code that I have to set? Any help is greatly appreciated.
    Manuel A. Ayala
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Icons not moving to the top of custom flyout toolbars
    Many years since I've used a toolbar but I found it in AutoCAD Help: https://help.autodesk.com/view/ACD/2...5-CF1353706A80
    The following table shows the properties for the Zoom flyout as they appear in the Properties pane. Use Own Button looks like what you're looking for.
    Properties for the Zoom flyout on the Standard toolbar
    Properties pane item Description Example
    Name String that does not appear in the user interface unless the Use Own Button property is set to Yes. Zoom
    Description Text used to describe the element, does not appear in the user interface.
    Source Toolbar A read-only value used to specify which toolbar is being referenced to create the flyout. TB_ZOOM
    Use Own Button Controls whether the last used toolbar button is set as the current button or not. No
    2001-01
    257
    Hi Tom
    Sorry for the delay in response. Your suggestion worked beautifully. Thank you so very much. Take care.
    Manuel
  1. Replies: 5
    Last Post: 2009-03-05, 11:12 PM
  2. Flyout within a flyout
    By ticad02 in forum AutoCAD Customization
    Last Post: 2008-12-23, 06:06 PM
  3. Creating new Custom Icons for toolbars
    By Kal_digital in forum AutoCAD Customization
    Last Post: 2008-03-03, 08:26 PM
  4. Tool Palette flyout button icons not updating
    By Paul Munford in forum AutoCAD General
    Last Post: 2007-11-16, 05:54 PM
  5. Flyout Last Pick Remains on Top
    By Peter.C in forum AutoCAD Customization
    Last Post: 2007-10-26, 03:21 PM
