Thread: PROPERTY SETS
    2018-03
    52
    Default PROPERTY SETS
    Hi all
    I have just been given a new job that involves supplying roof areas for material quotes,
    I have a schedule that shows the net area of each roof slab and the total area of all the slabs
    it is very accurate.
    the problem is I cannot assign the property set "net area" to the roof style.
    I have to select each roof slab and open the properties palette and in extended data tab add the property set "net area" to each slab individually.
    Once this is done the schedule works fine.
    I know its penny pinching but it would save me time if the property set was added to the roof slab style that way every time I converted a roof to slabs, the schedule would work with out having to spend time adding the property to each slab.
    any ideas
    any one?
    thanks in advance
    John
    Member robin.capper's Avatar
    2002-06
    New Zealand
    48
    Default Re: PROPERTY SETS
    Hi,
    If you schedule the elements using a schedule with that property in it you'll get '?'s. Right click the Schedule Table and select 'Add all Property Sets' and it should populate the missing sets on the objects
    2018-03
    52
    Thanks Robin,
    I have got it now.
  1. Replies: 8
    Last Post: 2006-06-27, 04:30 PM
  2. Property Sets - Wall Area / Spaces
    By mcorrea in forum ACA General
    Last Post: 2006-05-17, 04:54 PM
  3. Column Bubbles, Grid Lines and Property Sets
    By phyllisr in forum ACA Wish List
    Last Post: 2005-11-03, 02:51 PM
  4. Property Data Sets - Object Overrides
    By welk3d-cad1 in forum ACA Wish List
    Last Post: 2004-12-23, 03:17 PM
  5. Window and Space Object Property Sets
    By arcadia_x27 in forum ACA General
    Last Post: 2004-07-03, 12:53 AM
Tags for this Thread
