Results 1 to 6 of 6
Thread: Editing blocks for Detail Component Manager
    Default Editing blocks for Detail Component Manager
    I am having a problem of editing inserted blocks, that I have pulled from the Detail Component Manager (ie Brick) in AutoCad Architecture 2022. In the past, I could insert brick into my drawing and the right click and edit the block in place. Now with 2022, I have to copy and rename the block to something else non-anonymous to be able to edit in place. If I try to edit the block pulled straight from the detail component manager, I get the message "Cannot Refedit ANONYMOUS Block", what gives. I can complete the edit in Autocad Architecture 2021.
    Scott
    2019-04
    2
    Default Re: Editing blocks for Detail Component Manager
    Did you ever find a solution to this? I've been having the same issue and would love to get it corrected!
    Josh
    I have not. The only thing that I can find at this time is to rename the block and then edit it. I am still searching and if I find out, I will let you know.
    Turlock, CA
    6,420
    Since you can perform the action in 2021 but not 2022, I would say it is a bug. Go to your account and on the Home tab, select the Support Cases button. It will take you here. Start a new technical support case and report the bug.
    Out of curiosity, can you edit it in the block editor instead of in-place? What about other blocks, not just brick? Is the problem with the block or with the editor?
    C:> ED WORKING....
    LinkedIn
    2019-04
    2
    Since you can perform the action in 2021 but not 2022, I would say it is a bug. Go to your account and on the Home tab, select the Support Cases button. It will take you . Start a new technical support case and report the bug.
    I'm pretty sure it's the editor as it doesn't matter which block is inserted, I have to rename it before I can edit it. I'll get the support case a try and see what comes of that. Thank you!
    Turlock, CA
    6,420
    Did you try the block editor instead of in-place?
    C:> ED WORKING....
    LinkedIn
  1. Site component with Detail component
    By dhurtubise in forum Revit Architecture - General
    Last Post: 2007-05-29, 05:49 AM
  2. Detail Views / Group / Component Manager Request...
    By ronjon in forum Revit Architecture - Wish List
    Last Post: 2005-07-26, 08:41 PM
  3. Detail Component Manager
    By pnorman in forum ACA General
    Last Post: 2005-04-06, 05:38 PM
  4. 3D Detail component manager
    By cadkiller in forum Revit Architecture - Wish List
    Last Post: 2005-01-04, 11:16 AM
  5. Detail component manager
    By dg in forum ACA General
    Last Post: 2004-08-24, 12:16 PM
