Results 1 to 7 of 7
Thread: Cannot pull up the map using geolocation set
    2016-04
    California
    149
    Default Cannot pull up the map using geolocation set
    Ok, I see the underlying map in the model view but it is a little off from my line work. So I go to shift the map a little...I have done this thousands of times... by clicking Edit Location> From Map and although I get the Graphic Location window, I just get the spinning circle and no map. See first attachment. I have tried rebooting everything and I even tried removing the geo location and re-identifying it but no luck. Also when I click on Reorient Marker command I get the second attached warning. Oh one more thing, I did the Audit command and yes there were some errors but ACAD says they were fixed.
    As always, any help appreciated.
    TT
    Active Member dotson's Avatar
    2005-01
    56
    Default Re: Cannot pull up the map using geolocation set
    Since you're using the plain AutoCAD GeoLocation tool that lets you pick random locations and enter an address, do you have a statement on your drawing that "the geolocation presented here is fictitious and any resemblance to an actual geolocated drawing is purely coincidental"? I've seen would be geolocated drawings in inches, millimeters, have small world coordinates in the teens, hundreds and they equate to 'GeoGarbage'. You can't accurately export to KML, you can't merge in other 'truly geolocated' content, and sending the drawing to a knowledgeable client is asking to be removed from further consideration of work.
    Cairo - no, not Illinois
    5,069
    Agreeing with dotson. Since you are posting in the C3D forum, I would assume that you have Civil 3D, and can actually set a real coordinate system for the drawing in Toolspace Settings Tab|Drawing Settings.
    Given that, trying to un-georeference it using the vanilla Acad stuff makes no sense. Better to locate a map that is correctly georeferenced rather than the Bing stuff in the GeoMap command. (The latter is fine for county level planning purposes, but far to inaccurate for site work or development)
    Try the National Map if in the US.
    2015-12
    Arizona
    2,478
    Were did you get, or where are you getting the MAP from?
    It is possible that it is wrong, and or has a different coordinate system attached to it. (Yes it happens)
    Try something like QGIS, it's free
    Import that map and see what CS is actually assigned to it.
    It's a good way to quickly verify GIS data.
    2016-04
    California
    149
    Cadtag,
    Yes I am using Civil 3D 2017. Old I know but my business partner wants to use this version. Anyway, yes I have set the coordinate system like I always have before. I use CA83IIF where I am. Incidentally, I tried changing the coordinate system but still no luck. Note, this problem started after I cleaned up some files off my hard drive (running out of RAM and getting those running out of memory notices). So I am wondering if I may have lost a file. Since the map info is taken off the internet though I would think this would make no difference. I have also tried logging off the 360 server and logging back on...no luck.
    As a general question, since I am not a computer code guy, when you use the "Audit" command, doesn't this replace or "fix" any files that are missing or corrupted?
    TT
    5,069
    Bing map quality is poor, and not good enough for design work. (useful for large area b0g-picture type planning or location maps, but not a good site-level. IIRC i've gotten as much as 2 mile location error using Geomap on 2014 around Naples Fl area. Later versions were better, but a 20 ft to 20 meter mismatch is typical))
    Audit will only look for errors in the actual DWG file, and will not affect other files on the computer -- You can try to re-install or repair the 2017 install from Control Panel, but you really need a better quality georeferenced map to work with.
    2015-12
    Arizona
    2,478
    You still did not tell us where you got the georeferenced imagery from.
    Where did it come from and what coordinate system is actually assigned to it are a big deal in getting it to line up correctly.
  1. 2017: C3d and Geolocation vs. CAD-Earth
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2017-03-21, 01:15 PM
  2. 2014: Geolocation Panel always starts
    By cadtag in forum AutoCAD CUI Menus
    Last Post: 2016-02-16, 03:36 PM
  3. 2016: aerial imagery & Geolocation
    Last Post: 2016-01-07, 08:12 PM
  4. 2015: Geolocation Online Map Data
    By wbt@tswcd in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2015-07-24, 10:24 PM
  5. Locating Xref using Geolocation not available if Xref is open
    By svajk394200 in forum Geospatial - General
    Last Post: 2013-06-25, 10:01 PM
Tags for this Thread
