Results 1 to 1 of 1
Thread: Copy Revcloud from Xref compare
    Wish List Administration
    2011-08
    4,581
    Default Re: Copy Revcloud from Xref compare
    Summary: Copy Revcloud from Xref compare
    Description: Copy Revcloud from Xref compare with the ability to add a revblock for the number of times it has changed.
    Product and Feature: AutoCAD - XREF
    Submitted By: valentine on 07/15/2021
    2011-08
    4,581
    Exclamation Re: Copy Revcloud from Xref compare
    Copy Revision Cloud from Xref Compare Feature
    Summary: Copy the "Revision Cloud" active and on its own layer (with date) from the "Xref compare" feature, with the ability to modify it thru properties.
    Description: Copy the "Revision Cloud" active and on its own layer (with date) from the "Xref compare" feature, with the ability to modify it thru properties.
    2011-08
    4,581
    2011-08
    4,581
    2011-08
    4,581
    Copy Revision Cloud from Xref Compare Feature Active
