Thread: PDF import no longer working
    2005-07
    Melbourne, Australia
    96
    Default PDF import no longer working
    Recently I tried importing PDF file into Revit 2021 and received spinning wheel then Revit shuts down without any warning/notification
    Previously Revit would give option of sheet number of pdf file then import file with no problems
    \Now no longer works with importing image files...png. jpg. Works in AutoCAD. Time to switch back to autoCAD?
    2012-11
    33
    Default Re: PDF import no longer working
    You might want to do a re-installation from the Adesk installer.
    If that doesn't work, you might do a clean install of Windows and download all the latest goodies from windows update. Then do a clean install of Revit. I know that sounds extreme, but all manner of quirks, bugs and misbehaviors will disappear if you flush windows and start fresh. --> I do this annually as a general housekeeping thing, it's like buying a new pc, everything runs fast and works.
    2005-07
    96
    Your solution sounds extreme, but I did previously rely on pdf import from clients, and only update I have installed is adobe acrobat DC.
    Could this be the problem. Worked fine prior to this
  1. Sheet Set Code no longer working in VS2015
    By mcoffman in forum Dot Net API
    Last Post: 2015-10-21, 02:42 PM
  2. ATTEDIT (dialog version) no longer working in macro
    By scott.wilcox in forum AutoLISP
    Last Post: 2010-01-12, 09:29 PM
  3. Hatchsetorigin no longer working.
    By chowe in forum ACA General
    Last Post: 2008-07-16, 03:33 PM
  4. ADT 3.3 Spell Check no longer working
    By bercherdbrc138323 in forum ACA General
    Last Post: 2007-06-19, 05:17 PM
  5. Editing via "Profile Grid View" not working any longer
    By b.mossman in forum AutoCAD Civil 3D - General
    Last Post: 2005-08-15, 04:02 PM
