Thread: WALL HATCHING SHOWS ON WINDOW
    2018-03
    52
    Default WALL HATCHING SHOWS ON WINDOW
    Hi all
    I have a tricky one but I'm sure that the answer is easy.
    I have created a block for a custom window. when I insert the block it works fine, however when I generate the elevations in the view tab the wall hatching continues through the window as if it wasn't there.
    I have tried to attach an image I hope it works
    Again thanks in advance for any help you can give.
    Turlock, CA
    6,419
    Default Re: WALL HATCHING SHOWS ON WINDOW
    It might be better if you shared the dwg. At least a wall with the problem window in it.
    C:> ED WORKING....
    LinkedIn
    2018-03
    52
    Hi Ed.
    Thanks for the reply
    I have fixed the problem with your help.
    I tried to upload the dwg file but it was too big for this forum so I separated the wall and window, created elevations from the wall and window and the problem was gone.
    I realised that the problem, again was the interface between the seat and the key board. I had inadvertently added the same material to the internal wall behind the window and that was the hatch that was showing.
    Thanks again for your help.
    John
    Turlock, CA
    6,419
    lol, glad you got it fixed.
    C:> ED WORKING....
    LinkedIn
  1. 2019: Some Window families shows Blanks on schedule
    By akai182415554 in forum Revit Architecture - General
    Last Post: 2019-08-09, 08:48 AM
  2. Revit dosent open Error window only shows !
    By Kenny Gee in forum Revit Architecture - General
    Last Post: 2008-12-04, 10:58 PM
  3. Replies: 5
    Last Post: 2007-07-13, 05:24 PM
  4. Dockable window that shows open drawings
    Last Post: 2006-01-05, 05:56 PM
  5. Demo infill still shows in new window
    By anthony.67953 in forum Revit Architecture - General
    Last Post: 2005-12-10, 02:03 AM
Tags for this Thread
