Results 1 to 1 of 1
Thread: Annotation scales - variable, standards, commands
    Wish List Administration
    2011-08
    4,581
    Default Re: Annotation scales - variable, standards, commands
    Summary: 1) Create a variable that controls annotation scales through Attached XREFs and inserted Blocks.
    2) File to customize all the company standard AS list and a command to recall it.
    Description: XREFs or blocks "imports" their annotation scale in current drawings.
    and due to the fact that the unused A.S. are not included in the PURGE command
    2 features that could be very helpful could be:
    1) Varaible to control HOW the AS are imported.
    EXAMPLE:
    ASVAR (variable)
    0 = Default------] all the Xrefs or blocks imports the AS
    1 = Only Blocks imports the AS
    2 = Only Xrefs imports the AS
    3 = No file/object from outside the current drawing imports AS
    2) Resetting the AS with -SCALELISTEDIT ] Reset ] Yes
    is quite good but if a company normally works with their own AS list could be awesome and timesaving to have a TXT file to edit (that contains all the data, parameters and names of the AS) and a command to recall all the company's custom AS list.
    EXAMPLE:
    annoscalelistcustom.asl (Filename in the Support folder, such as PGP etc....)
    n.1 Annotation Scale per ROW comma separated
    Example: (for a mm standard file)
    "Company Name - 1:10";1;10
    "Company Name - 1:50";1;50
    etc..
    Example: (for a cm standard file)
    "Company Name - 1:10";10;10
    "Company Name - 1:50";10;50
    etc..
    "SCALELISTCUSTOM" (command to recall the AS list)
    Comand: SCALELISTCUSTOM ] "do you want to import your CUSTOM AS list?" ] YES ... done.
    Hope these feature will be ranked cause is really annoying to keep all the dwgs neat and clean.
    Product and Feature: AutoCAD - Other
    Submitted By: castellani.inteso on 07/28/2021
    2011-08
    4,581
    Exclamation Re: Annotation scales - variable, standards, commands
    EXAMPLE:
    ASVAR (variable)
    EXAMPLE:
    etc..
    etc..
