Thread: Recessed window
    2021-08
    Default Recessed window
    Working on a recessed window family. The goal is to have the glass and the mullions inset 3 inches from the exterior face of the wall. I am able to inset the glass but I am unable to inset the front face of the mullions 3 inches without disjoining them from the reference plane, or moving a reference plane which shifts other elements of the family. Wondering if there are any tips to achieve this. See attached image [Mullions at exterior wall] - this is what it looks like now. For desired look, see [Recessed mullions]. Thank you in advance for any advice!
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: Recessed window
    Can you share a snip of the Ref Level or side view with the reference planes showing?
    The key I've found to making things like this work is making sure there are reference planes (and ref lines when necessary), which are controlled by the parameters. Then the geometry is constrained to the references. From what you've noted, it sounds like you're trying to dimension to 3D geometry and not references.
  1. Recessed Window in wall with exterior stone veneer
    By abink in forum Revit Architecture - General
    Last Post: 2007-05-04, 07:16 PM
  2. Recessed Window Head
    By mylesa in forum Revit Architecture - General
    Last Post: 2006-01-19, 10:28 PM
  3. Recessed Lights
    By chriscooper in forum Revit Architecture - General
    Last Post: 2004-08-10, 02:45 AM
  4. Recessed lights in a floor/ceiling assembly
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-05-10, 07:47 AM
  5. Recessed Medicine Cabinet
    By hdjohnson in forum Revit Architecture - Families
    Last Post: 2004-01-06, 10:32 AM
Tags for this Thread
