Results 1 to 8 of 8
Thread: Change color of dim text overrides
    2005-06
    21
    Default Change color of dim text overrides
    I would like to change the color of manual dim text overrides as they are created. Is there a variable setting for this or a lsp routine perhaps?
    Dennis
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Change color of dim text overrides
    Try Kent Cooper's code at: https://forums.autodesk.com/t5/visua...107144#M323608
    Change "(vlax-put obj 'Color 256); = Bylayer" from Bylayer to whatever color you wish.
    2005-06
    21
    Thanks Tom. I don't want the text on a new layer though, I just want the over-ridden text to be a different color. Any suggestions? I'm not much of a lisp user so modifying the code is bit beyond me without some guidance.
    Dennis
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by dennis.moyes View Post
    Dennis
    The variable for the assigning a color to the dimension text is "dimclrt"
    (example)
    (setvar "dimclrt" 1) ;;sets the color to 1 (red)
    2005-06
    21
    That still puts it on a new layer though, right?
    2005-06
    21
    This is too complicated. I need a simple routine that answers 1 if/then statement: IF there is text in the dim text override property THEN change its color.
    Cairo - no, not Illinois
    5,069
    I think that would be a usefule idea, but it's not something you'll find out of the box. I'd suggest posting in the customization forum and requesting someone to help you code a .LSP routine.
    2005-06
    21
    Thanks. I'll post if over there,
  1. Replies: 3
    Last Post: 2012-12-19, 03:00 PM
  2. Dim Text Above the Dim Line
    By BeKirra in forum AutoLISP
    Last Post: 2012-06-19, 08:26 AM
  3. Replies: 4
    Last Post: 2010-02-23, 05:36 PM
  4. dim style overrides automatically. There is a button...
    By jniessen in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-03-28, 04:35 PM
  5. Retain Dmension Overrides When Creating A New Dim Style
    Last Post: 2007-07-22, 05:17 AM
Tags for this Thread
