Thread: PDF to AutoCAD
    2017-06
    Default PDF to AutoCAD
    Esteemed fellow AUGI members....
    I am using AutoCAD 2022. It's been a while since I have had to use AutoCAD. I am creating Architectural backgrounds, relying on Construction Document PDF's. I can easily import a PDF and trace over it. However, I am finding many videos on YouTube where apparently AutoCAD can convert the PDF to AutoCAD layers automatically. This would be a huge time-saver. However, when I follow the steps that I am watching on youtube, the best I get is a raster image of the PDF. I never get the PDF to actually convert to AutoCAD. Is that possible, or what am I doing wrong?
    Turlock, CA
    6,420
    Default Re: PDF to AutoCAD
    You aren't doing anything wrong. PDF's are like zip files. When you import them, you get what is stored inside them. In this case, the dwg was converted to a raster image when plotted to pdf. You can choose what options to use when you plot to pdf. Either the consultant didn't realize that they had is set to raster, or they are doing it intentionally to protect their work.
    C:> ED WORKING....
    LinkedIn
    2014-04
    39
    the PDF has to be saves out of PDF software such as Acrobat with layering turned on. it will not convert scanned PDF or PDF's that have not been saved correctly.
    Cairo - no, not Illinois
    5,069
    whether layering is enable in the PDF or not doesn't matter. What does matter is whether the PDF has vector information, or image information. Vector can be imported, image has to be traced.
    Of course, the precision in a PDF is much lower than a DWG file work with, so importing can get ugly....
  1. Pdf as an ole not appearing on pdf printing...
    By bddcc in forum AutoCAD Plotting
    Last Post: 2007-07-12, 07:42 PM
  2. Adobe PDF vs Acad PDF file size info.
    By madcadder in forum AutoCAD Plotting
    Last Post: 2006-11-30, 06:06 PM
  3. AutoCAD 2007 - DWG to PDF, Mac user unable to Open/Print PDF's
    By john.113502 in forum AutoCAD Plotting
    Last Post: 2006-06-06, 01:11 AM
  4. Multi-Page PDF using the Revit PDF Writer.
    By Paul Monsef in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-06-05, 02:46 PM
