Thread: Routine that Toggle XREFs On/Off
    2013-02
    49
    Default Routine that Toggle XREFs On/Off
    Hi Everyone
    Could anyone help me create a Routine that Toggle XREFs instead of Loading/unloading it or turning the Xrefs Layer On/Off.
    I Already have the Reference Manager Toggle Routine.
    Thank you in advance.
    2009-11
    5,719
    Default Re: Routine that Toggle XREFs On/Off
    You can roll your own LISP for this, but have you tried the HIDEOBJECTS Command?
    It's basically the reverse of ISOLATEOBJECTS.
    To show the hidden objects again, simply use the UNHIDE Command (which is really the UNISOLATEOBJECTS Command).
    Another benefit to this, is unlike using LISP to set Visible Property to False, the hidden objects will still appear unhidden automagically after a drawing is saved (with them hidden), closed and reopened.
    HTH
    Computer Specs:
    2005-06
    in the upper right corner
    3,507
    I use a routine that freezes or thaws the xref layer(s) (the layers that the xref is on)
    I know you mentioned you didn't want that but I use this all the time.
    (example of standard NCS-named xref layer)
    ;;thaws layer named "G-ANNO-REFR"
    (defun c:TXR () (command "layer" "thaw" "G-ANNO-REFR""")(princ)
    ;;freezes layer named "G-ANNO-REFR"
    (defun c:FXR () (command "layer" "thaw" "0" "set" "0" "freeze" "G-ANNO-REFR""")(princ)
    I also have other layers for different disciplines, like the arch floor plan on an arch xref layer to freeze/thaw separately from other xrefs:
    ;;thaws layer named "A-ANNO-REFR"
    (defun c:TAXR () (command "layer" "thaw" "A-ANNO-REFR""")(princ)
    ;;freezes layer named "A-ANNO-REFR"
    (defun c:FAXR () (command "layer" "thaw" "0" "set" "0" "freeze" "A-ANNO-REFR""")(princ)
    These are basic routines,
    Just a suggestion.
    2002-08
    231
    One of my routines from 2006, see if it can still do the job.
    (defun c:layer_xref_on-off ( / a name name_dir name_lay)
    	(setvar "cmdecho" 0)
    	(setq a (tblnext "block" t))
    	(while a
    		(if (= (logand (cdr (assoc 70 a)) 4) 4)
    			(progn
    				(setq name (cdr (assoc 1 a)))
    				(setq name_dir (strcat (vl-filename-directory name) "\\"))
    				(setq name_lay (strcat (vl-string-right-trim ".dwg" (vl-string-subst "" name_dir name)) "|*"))
    				(command "_.-layer" (if (zerop (getvar "USERI1")) "_off" "_on") name_lay "")
    		(setq a (tblnext "block"))
    	(if (zerop (getvar "USERI1")) (setvar "USERI1" 1) (setvar "USERI1" 0))
    	(setvar "cmdecho" 1)
    	(princ)
    2013-02
    49
    @Bruno.Valsecchi this routine is exactly what I needed! Thank you so much!
    Thank you all for your time!
    You are all awesome!
  1. Replies: 3
    Last Post: 2019-05-07, 05:19 PM
  2. Replies: 11
    Last Post: 2010-04-08, 09:03 PM
  3. Project Navigator - xrefs? what xrefs?
    By rodg in forum CAD Management - General
    Last Post: 2008-11-04, 08:21 AM
  4. Project Navigator - xrefs? what xrefs?
    Last Post: 2008-11-04, 08:20 AM
  5. XREFS - MSG not xrefs "Not Found"
    By spencer.67965 in forum VBA/COM Interop
    Last Post: 2005-01-18, 03:45 PM
