Thread: what is the revit equivalent of dim scale linear
    2021-09
    Default what is the revit equivalent of dim scale linear
    We manufacture modular homes - some with pitched roof and ceiling - which are made upside down on the floor before fitting to the building.
    In AutoCAD Architecture we use dims with a Dim Scale Linear to show the true length in plan from the edge of the room to the lighting position.
    is there an equivalent function in Revit ??
    in the upper right corner
    3,388
    Default Re: what is the revit equivalent of dim scale linear
    Good morning Roger, congrats on your first post!
    I'm not sure what you're asking, you mention linear dimensions and scale?
    If you mean "Units", that is set in your dimension styles, either use your global settings or set new ones.
    If you mean "linear" vs "aligned" dimensions, yes that is one of your dimension options.
    Hope this helps
  1. Replies: 9
    Last Post: 2015-08-21, 06:33 PM
  2. Linear Parameters vs. Linear Dimensional Constraint
    By melissa_r_alexander in forum Dynamic Blocks - Technical
    Last Post: 2010-07-09, 05:10 PM
  3. Dim Linear Scale
    By tntdraftsol in forum AutoCAD Annotation
    Last Post: 2010-06-03, 09:35 PM
  4. Replies: 2
    Last Post: 2006-07-06, 08:58 PM
