I want to create a Sheet Custom property that would be the Field of the second line of the sheet title ("Title Line 2" in image) would be distinctive per sheet.
in this case the second line would be different street names.
yes? and the question is??
If it's how to set the sheet custom property, one way is to right click on the sheet in SSM, and choose Properties from the context menu.
Is your title block using attributes or is it text or mtext for the existing ones seen on the left?
Then you need to update the block using REFEDIT and have it updated across your drawings.
See Change attribute order of block in many CAD drawings
