Thread: Script to manipulate layers in multiple x-refs
    2015-10
    2
    Default Script to manipulate layers in multiple x-refs
    Hi all,
    I am currently working on my first script attempting to change specific xref dependent layer properties to show as needed in my drawings.
    We had a similar script at my previous place of employment so I know it can be done but am having trouble because the changes are made to all xrefs in the dwg.
    Concrete plan - Concrete level below gets xref'd and named X-CONC-B
    Wood frame plan - Wood level above gets x-ref'd and named X-WOOD-A
    All but a few layers are turned off.
    Remaining layers have colour changed and linetype changed to hidden or hidden2.
    Trouble is that layers are the same in other xrefs (X-GRIDS, X-SCHEDULES etc..)
    This is what I have and it works for the layer changes I want but, turns off all layers that begin with S-,~- & BDR- in other xrefs I don't want to edit.:
    -LAYER C 40
    *|X-*
    L HIDDEN
    *|X-CONC-B|S-CWALL*,*|S-WWALL*,*|S-WSW*,*|S-WOUTLINE*
    L HIDDEN2
    *|S-CCOL*,*|S-SCOL*,*|S-WPOST*,*|S-WHAT*
    C 3
    *|S-CCOL*,*|S-SCOL*
    C 254
    *|S-ARCH*
    F
    *|S-*,*|~-*,*|BDR-*
    T
    *|S-CWALL*,*|S-CCOL*,*|S-SCOL*,*|S-WHAT*,*|S-WWALL*,*|S-WSW*,*|S-WOUTLINE*,*|0*,*|S-ARCH*
    Is there a way to tweak so I turn off layers in X-WOOD-A AND X-CONC-B only?
    For example the layer ~TXT20 exists in all xrefs.
    X-CONC-B|~TXT20
    X-WOOD-A|~TXT20
    xxxx-xxx-X-Schedules|~TXT20
    (lower case x's = project number)
    Thanks for helping a noob to script writing.
    Marlon
    2009-11
    5,709
    Default Re: Script to manipulate layers in multiple x-refs
    Not sure if I fully understand what you're asking for, but sounds like you're wanting to change this:
    -LAYER C 40
    *|X-*
    L HIDDEN
    L HIDDEN2
    C 3
    *|S-CCOL*,*|S-SCOL*
    C 254
    *|S-ARCH*
    F
    *|S-*,*|~-*,*|BDR-*
    T
    To this:
    -LAYER C 40
    *|X-*
    L HIDDEN
    L HIDDEN2
    C 3
    *|S-CCOL*,*|S-SCOL*
    C 254
    *|S-ARCH*
    F
    X-WOOD-A|S-*,X-WOOD-A|~-*,X-WOOD-A|BDR-*,X-CONC-B|S-*,X-CONC-B|~-*,X-CONC-B|BDR-*
    T
    Computer Specs:
    2015-10
    2
    Red face Re: Script to manipulate layers in multiple x-refs
    Hi Blackbox,
    That did it!
    I had tried a variation of the line in blue but somehow had the symbols in the wrong order.
    Thank you so much.
    2009-11
    5,709
    Quote Originally Posted by Macoy_ View Post
    That did it!
    Thank you so much.
    Happy to help.
    Computer Specs:
  1. 2015: AutoCAD LT Script that changes multiple attributes across multiple drawings
    By alecgburke704194 in forum AutoCAD LT - General
    Last Post: 2015-06-30, 12:21 PM
  2. Replies: 2
    Last Post: 2013-05-23, 01:26 PM
  3. Manipulate Leader associated with a Block
    By afortier in forum AutoCAD General
    Last Post: 2005-04-29, 01:14 PM
  4. View X-refs When Isolating Layers
    By lhood in forum AutoCAD Wish List
    Last Post: 2005-01-19, 10:41 AM
  5. HOW TO MANIPULATE CONTOURS?
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-08-10, 05:44 PM
Tags for this Thread
