Thread: Revit viewport title centered with line?
    in the upper right corner
    3,502
    Default Revit viewport title centered with line?
    Not sure if this has been asked or figured out, I haven't found it yet.
    Is there a way to have the extension line centered and grow outward in each direction when stretched in view title?
    I want a title and the scale center justified with the line stretchable from the center.
    I suspect you would put the tags and text centered at the fixed reference point and have the line grow out in each direction, but I don't know if that is possible or how to do it.
    (see screen shot, this is what I have now which works but not ideal)
    (another option would be simply have the title text underline and turn off the extension line and keep it all centered)
    2018-04
    VOLS FAN STUCK IN NOTRE DAME
    30
    Default Re: Revit viewport title centered with line?
    You could use reference lines to control the line however the problem lies in not being able to lock the text to the center reference line. Not sure how to do this.
  1. Viewport Title Location In reference to viewport
    By BSaunders in forum Revit Architecture - General
    Last Post: 2010-10-27, 03:54 PM
  2. Replies: 4
    Last Post: 2010-02-23, 05:36 PM
  3. Field centered on line
    By lpseifert in forum Dynamic Blocks - Technical
    Last Post: 2008-06-09, 05:21 PM
  4. Rotation of Viewport & Viewport Title
    By iankids in forum Revit Architecture - General
    Last Post: 2007-12-19, 01:24 AM
  5. Place the text centered on dimension line
    By gravelin in forum Revit Architecture - Wish List
    Last Post: 2005-01-09, 06:12 PM
