for some reason I cannot get this to work. I have a small text file (comma delimited) that has latitude, longitude, description (latitude and longitude in decimal degrees.
I created a format that had a column for latitude (DECDEG Latitude) longitude (DECDEG Longitude) and raw description. wasn't sure about the raw description since its just a description of the point.
(see image below).
When I would run the import points command, it gave a red circle with an X in it and a status of no point file format found.
when I selected the second button in the specify point file format, all I got in the preview were the 3 categories and under the DECDEG latitude column was (see image below)
what am I doing wrong? I have to do this operation fairly often and what like for it to be a little more automated than imputing it in by hand.
