Thread: Block insert Repeat Placement & Rotate
    Wish List Administration
    2011-08
    4,581
    Default Re: Block insert Repeat Placement & Rotate
    Summary: In previous version we could use rotate and repeat placement and each placement could be independently rotated, useful, 2022 AutoCAD sets it to the same angle as first placement, not useful.
    Description: In previous version we could use rotate and repeat placement and each placement could be independently rotated, useful, 2022 AutoCAD sets it to the same angle as first placement, not useful, don't understand why anyone would want this. Imagine want to place doors, windows, radiator block around a building, each one would need to be at a different angle around the building. In 2022 the functionality was changes such the next placement would be fixed to the first rotation angle so a north window placement could not then be used to move around the to quickly place the rest of windows on the east, south & west walls. Now it is a start stop operation. Please return the Repeat Placement option to how it was in 2021.
    Product and Feature: AutoCAD - Blocks
    Submitted By: Greg Benson-Shettle on 10/19/2021
    2009-11
    5,650
    (defun c:I ()
        (command "._classicinsert")
        (princ)
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
