Results 1 to 10 of 10
Thread: select dynamic blocks
    2011-07
    The Netherlands
    63
    Default select dynamic blocks
    Hi guys,
    When I want to select all blocks with a specific name in drawing area + all layouts, I use this command:
    (sssetfirst nil (ssget "_x" '((0 . "INSERT") (2 . "123"))))
    With this code I have selected all blocks with the name "123" in the model space and also all layouts.
    However, this does not work with Dynamic blocks... Is there also a way to select dynamic blocks?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: select dynamic blocks
    Have you tried a search in the AutoLISP forum here? That has come up once or twice there.
    2011-07
    The Netherlands
    63
    Yes, but many threads and I lost after page 9 or so.. I did not see any thread with the same question.
    Do you have any link for me?
    2002-01
    jUSt Here (a lot)
    9,106
    And that was after you searched that forum? Weird. I found something on the subject here and here. Both were in the top five in a search for "ssget dynamic blocks" in that forum.
    2011-07
    The Netherlands
    63
    Thank you,
    I found those already, but they don't answer the question. I want to sellect dyn blocks in modelspace + layout.
    If I would like to select them only in modelspace, I could use 'selectsimilar', that also works for dyn blocks. However that is another case.
    2002-01
    jUSt Here (a lot)
    9,106
    The problem with dynamic blocks is once they are modified, the reference name is changed to an anonymous name. That is why your group code "2" doesn't work.
    To select all of the dynamic blocks for the name you are supplying to group code "2", you will need to cycle through all of the entities in a selection set containing all blocks in your drawing or layout. For each entity in your selection set, you will need to convert them to a VLA-OBJECT to allow you to query the EffectiveName property to match your block name.
    You could also modify the code T. Willey posted about querying the model space entities to do what you are attempting to do.
    Cairo - no, not Illinois
    5,069
    It's not possible to create a selection set that spans multiple layouts and model space. What you will have to do is create a routine that selectes your blocks in model space, _does something with them_, and then sequentially step through each layout tab, creating a new selection set of your dynamic blocks, do something with them, and go on to the next layout tab. Gathering them all into a single selection set is just not a capability of autocad.
    2009-11
    5,719
    Quote Originally Posted by peysey View Post
    Hi guys,
    Thank you,
    Not sure that you understand the difference between a Pickset and a SelectionSet.
    SelectSimilar 'selects' (onscreen) a Pickset - the set of entities that is actively 'selected' (picked) onscreen, that shows up in Properties Pane, etc. You can only 'select' (pick, onscreen) entities on your current tab (model, layout, etc).
    SelectionSets are programmatic and when used with "_x" selection method, contain entities from the entire database, which includes model, layout, etc. These entities can be iterated, and even modified (programmatically), but cannot be 'selected' (picked, onscreen) if they do not reside on the active tab (CTAB sysvar).
    To add to Opie's and cadtag's apt posts, please consider this example:
    (vl-load-com)
    (defun c:BlockCount (/ blockName i ss)
      (if
        (and
          (setq blockName (getstring "\nEnter block name: "))
          (setq blockName (strcase blockName))
          (ssget "_x" '((0 . "INSERT")))
        (progn
          (setq i 0)
          (vlax-for	x (setq ss (vla-get-activeselectionset
    			     (vla-get-activedocument (vlax-get-acad-object))))
    	(if (= blockName (strcase (vla-get-effectivename x)))
    	  (setq i (1+ i))
          (prompt (strcat "\n** " (itoa i) " blocks found ** "))
          (vla-delete ss)
      (princ)
    Computer Specs:
    2011-07
    The Netherlands
    63
    Hi guys, Thank you!
    I'm not (yet) capable of reading lisp codes, but I think I should change "blockname" to my own blockname? I did that by changing it to 123 (tha is my dynamic blockname):
    However, I could not let it work...
    What am I doing wrong?
    (defun c:BlockCount (/ 123 i ss)
      (if
        (and
          (setq 123 (getstring "123"))
          (setq 123 (strcase 123))
        (progn
          (setq i 0)
    	(if (= 123 (strcase (vla-get-effectivename x)))
    	  (setq i (1+ i))
          (vla-delete ss)
      (princ)
    2009-11
    5,719
    Hi guys, Thank you!
      (if
        (and
        (progn
          (setq i 0)
    	  (setq i (1+ i))
          (vla-delete ss)
      (princ)
    No, you should not do that.
    Please try the sample code before modifying it, and it might make more sense.
    Cheers
    Computer Specs:
  1. Quick Select &Dynamic; Blocks
    Last Post: 2018-03-09, 05:00 PM
  2. Dynamic Blocks - Creating dynamic bolt blocks
    By jake1889 in forum Dynamic Blocks - Technical
    Last Post: 2014-08-08, 12:56 PM
  3. ssget to select inherited dynamic blocks
    Last Post: 2012-06-18, 03:20 PM
  4. Select Dynamic Blocks by Current Visibility State
    Last Post: 2009-07-05, 10:03 PM
  5. How select dynamic blocks with a determinate visibility
    By mateo in forum Dynamic Blocks - Technical
    Last Post: 2005-10-28, 08:42 AM
Tags for this Thread
