Thread: Attribute Size and Font changes when copied
    2005-01
    63
    Question Attribute Size and Font changes when copied
    Sometime ago I had created a Title Page template that contains an attribute that automatically updates to the current the date and time when the dwg is saved. When creating a new dwg I'll cut and paste the Title Page from an existing dwg and paste to the new dwg and in the process both the size of the window changes along with the font. What would be the cause of this and is there a way to correct? The way around now is to cut the new dwg and paste to the existing Title Page.
    Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Attribute Size and Font changes when copied
    Is the font style already in the destination drawing? You might look there to see if it matches your source drawing.
    2005-01
    63
    Sorry for the delayed response, forgot about this and not notified. When you say "is font style already in the dwg", yes it is Arial and used as text elsewhere but defaults to a predefined Standard which is called txt.shx.
    in the upper right corner
    3,507
    Quote Originally Posted by cjshaw View Post
    That may be the key to your problem.
    Is that attribute using the style named "Standard" (which is an OOTB style name) and has Arial.ttf assigned in one drawing and txt.shx to the other?
    You simply need to assign Arial.ttf to the style "Standard" in the template or drawing that is wrong.
    Or better still, create your block with attributes using a unique text style name or other company standard other than "Standard".
    Just a thought
  1. Replies: 0
    Last Post: 2020-03-17, 04:00 PM
  2. 2010: unwanted size changes of attribute text in dynamic blocks?
    By bstk in forum Dynamic Blocks - Technical
    Last Post: 2014-06-02, 10:31 AM
  3. Replies: 1
    Last Post: 2012-05-11, 09:16 PM
  4. Set up font size in AutoCAD to mimic Word text size
    By panchalashi in forum AutoCAD General
    Last Post: 2006-05-29, 12:22 PM
  5. Replies: 15
    Last Post: 2005-06-28, 06:43 PM
