Thread: Set annotative scale by object
    Wish List Administration
    2011-08
    4,581
    Default Re: Set annotative scale by object
    Summary: In model space, have the ability to set the current annotative scale by selecting an annotative object.
    Description: When working in model space, it would be nice to just be able to select an annotative object and be able to set the current annotative scale to match it. Currently you have to select the object, look at what it's annotative scale is and then go and set the current annotative scale.
    Product and Feature: AutoCAD - Dimensions
    Submitted By: robp on 10/29/2021
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,550
    As that would only work for annotative dimension not blocks or text this lisp should do what you want: https://forums.autodesk.com/t5/visua...326663#M302283
