hello
can someone could help me with this program i try to made in Lisp
the program is to automatically write revision on engeneering plan when new issue of plan or series of plan in sheetset
i can give the files by email if someone wants the template and drawing to work with the lisp
thank you and excuse my english
;;; 2021-nov-03 by Martin Duval from Rochon experts Infrastructel
;;; revision sheet lisp for autocad
;;; REC_REVISION REVISION 2021-NOV-11-1
;; dwg document property (DWGPROP) add this to this lisp work...
;01SheetRevisionNumber
;01SheetRevisionDate
;01SheetIssuePurpose
;01SheetRevisionBy
;02SheetRevisionNumber
;02SheetRevisionDate
;02SheetIssuePurpose
;02SheetRevisionBy
;or use the template
;;NEED ALSO BLOCK REFERENCE SSREV
;;;WORK WITH THE SHEET SET MANAGER OR FORCE THE DEFAULT FIELD VALUE IN SSREV BLOCK REFERENCE
(vl-load-com)
(defun c:rec_revision
(x / BlkName DwgName OldPath SSREVRN SSREVRD SSREVIP SSREVBY PNAME VERIFYSI TMP EPROP EVALUE DOC DB SI REVRN)
(princ "SheetSet REVISION\: " DWGREVSSRN)
(princ "REVISION A\: " DWGREVARN)
(princ "REVISION B\: " DWGREVBRN)
;;;CHEK IF "TESTSheetRevisionNumber" EXIST ON CUSTOM DRAWING PROPERTY IF NOT CREATE IT
(setq DOC (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq DB (vla-get-Database DOC))
(setq SI (vla-get-SummaryInfo DB))
(setq VERIFYSI (vla-get-summaryinfo
(vla-get-activedocument (Vlax-get-acad-object))
TMP 0
;IN: PNAME - property name to search as string (NOT case sensitive)
;OUT: returns t if property exists, else nil
(vla-GetCustomByIndex VERIFYSI TMP 'EPROP 'EVALUE)
(while (and (not (eq (setq EPROP (strcase EPROP))
(setq PNAME (strcase "01SheetRevisionNumber"))
(< (+ TMP 1) (vla-numcustominfo VERIFYSI))
(setq TMP (1+ TMP))
) ;while
(if (eq EPROP "01SheetRevisionNumber")
t
nil
;; MAIN PROGRAM
;;;; get value of attributes to lisp variables function DWGREVRN - DWGREVRD - DWGREVIP - DWGREVBY
;(function
; (lambda (x / BlkName DwgName OldPath)
(setq BlkName "SSREV")
(setq AttTagRN "SSREVRN")
(vlax-for lo (vla-get-Layouts x)
(vlax-for obj (vla-get-Block lo)
(if
(and
(= (vla-get-ObjectName obj) "AcDBlockreference")
(= (vla-get-Name obj) BlkName)
(foreach attRN (vlax-invoke obj 'GetAttributes)
(setq DWGREVRN (vla-get-TextString attRN)
(setq AttTagRD "SSREVRD")
(if
(and
(foreach attRD (vlax-invoke obj 'GetAttributes)
(setq DWGREVRD (vla-get-TextString attRD)
(setq AttTagIP "SSREVIP")
(if
(and
(foreach attIP (vlax-invoke obj 'GetAttributes)
(setq DWGREVIP (vla-get-TextString attIP)
(setq AttTagRV "SSREVBY")
(if
(and
(foreach attRV (vlax-invoke obj 'GetAttributes)
(setq DWGREVBY (vla-get-TextString attRV)
;;;; SET VALUE TO VARIABLES DWGREV(#)RN - RD - IP - BY from DWGPROP CUSTOM PARAMETRES PRESET IN TEMPLATE OR DRAWING
(setq DWGREVARN (vla-getcustombyKey SI "01SheetRevisionNumber"))
(setq DWGREVARD (vla-getcustombyKey SI "01SheetRevisionDate"))
(setq DWGREVAIP (vla-getcustombyKey SI "01SheetIssuePurpose"))
(setq DWGREVABY (vla-getcustombyKey SI "01SheetRevisionBy"))
(setq DWGREVBRN (vla-getcustombyKey SI "02SheetRevisionNumber"))
(setq DWGREVBRD (vla-getcustombyKey SI "02SheetRevisionDate"))
(setq DWGREVBIP (vla-getcustombyKey SI "02SheetIssuePurpose"))
(setq DWGREVBBY (vla-getcustombyKey SI "02SheetRevisionBy"))
;;; CONDITION IF BY DEFAULT %% IS THE VALUE OF SHEET SET REVISION OR NOT FOR EACH LISP VARIABLE DWGREVSS##
(cond
(/= "%%" DWGREVSSRN)
(setq REVRN 100)
;;; set value of custom revision number A if =/ revsion number sheetlist and if they are value rev 00=revsheetlist
(if
(and
(/= DWGREVARN DWGREVSSRN)
(= 100 REVRN)
(vla-setcustombyKey SI "01SheetRevisionNumber" 'DWGREVSSRN)
;;; set value REVRN1 IF CHANGE MADE ON VARIABLE DWGREVARN = DWGREVSSRN
(cond
(= DWGREVSSRN DWGREVARN)
(setq REVRN 1)
;;; set value of custom revision number A if =/ revsion number sheetlist and if they are value rev A=rev sheet list
(if
(and
(/= DWGREVBRN DWGREVARN)
(= 1 REVRN)
(vla-setcustombyKey SI "02SheetRevisionNumber" 'DWGREVSSRN)
;;; set value REVRN1 IF CHANGE MADE ON VARIABLE DWGREVBRN = DWGREVSSRN
(cond
(= DWGREVSSRN DWGREVBRN)
(setq REVRN 2)
;;etc THE PROGRAM IS TESTING FOR REVISION NUMBER
(vlax-release-object SI)
(vlax-release-object DB)
(vlax-release-object DOC)
(princ)
