Results 1 to 10 of 15
Thread: acad.pat file reports as missing
    2004-05
    Custer, Washington
    124
    Default acad.pat file reports as missing
    Hi all,
    Seems for about 2 months now I can't get my hatch patterns to work. I get an "acad.pat" can't find file and then a unable to open file: acad.pat, ERROR=1
    Can anyone explain the error here. The .pat files are in the support directory but for some reason it says it can't find them.
    Thanks in advance
    Kim
    Turlock, CA
    5,919
    Default Re: acad.pat file reports as missing
    Did you edit the acad.pat file? If so, you may have a syntax error.
    If you created your own pat file, try this. Put the pat files in a folder that is not part of the acad installation, e.g. a network folder. Then add that folder to the Support File Search Path list. Now the hatch command should find your pat file.
    C:> ED WORKING....
    2004-05
    Custer, Washington
    124
    No, I did not edit the file. But when I went to where it was supposed to be they were converted to a pdf file. I fixed that and then added them to our shared autocad folder and added it to the support file search path and still autocad says there are no .pat files to be found. I'm at a lose here.
    Cairo - no, not Illinois
    4,967
    well, then do a Repair of the installation, or Reset Settings to Default
    2005-06
    in the upper right corner
    3,381
    Did you say Autocad can or can't find the acad.pat file?
    Did you try on the command line:
    (findfile "acad.pat")
    Should return where it finds it or NIL if it cant.
    2004-05
    Custer, Washington
    124
    I tried (findfile"acad.pat") and get nil.
    Tell me if I do a repair or reset do I loose my workspace settings and toolbars?
    2001-03
    Tallahassee, FL USA
    3,550
    Search for acad.pat in Windows File Explorer, then copy it to your Roamable Support folder where it should have been on install.
    Entering
    (startapp "explorer" (strcat "/n,/e," (getvar "roamablerootprefix")"Support"))
    at the Command line should open your Roamable Support folder.
    You can use findfile to search for your other custom hatch patterns like (findfile "marsh1.pat").
    If findfile can't find them you wont be able to use them either.
    2004-05
    Custer, Washington
    124
    Ok so I did your code and it opened in the correct file and the files are there. I already checked this before and don't understand that acad says it can't find file.
    2001-03
    Tallahassee, FL USA
    3,550
    Quote Originally Posted by kimlance View Post
    Was that Support folder in Options => [Files] tab => Support Files Search Path?
    In Options => [Profiles] tab => try selecting another Profile and picking [Set Current]
    I save to a new profile whenever I'm about to mess with Options settings in case I mess something up. Resetting a good profile can save you a lot of grief.
    4,967
    Ok, let's go back to the point where you said it had turned into a PDF file. HOW did you fix that? Are file extensions visible in Windows File Explorer? (View tab, File Name Extensions is checked?)
  1. pat file location and ini file
    By Ning Zhou in forum Revit Architecture - General
    Last Post: 2010-08-08, 04:35 PM
  2. AutoCAD 2006 - Where do I find the ACAD.PAT file
    By trud1966 in forum AutoCAD General
    Last Post: 2007-03-25, 03:07 PM
  3. Wall Cut Pat. overides Column Cut Pat.?
    By nnguyen in forum Revit Architecture - General
    Last Post: 2006-09-21, 03:59 PM
  4. Revit.pat = Acad.pat
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2006-08-09, 03:14 PM
  5. acad.pat path error
    By satish in forum AutoCAD General
    Last Post: 2006-02-01, 12:27 AM
