Thread: Profile when opening AutoCAD 2022
    2015-11
    Dallas, Texas
    142
    Default Profile when opening AutoCAD 2022
    I know that if you open the software using a shortcut on the desktop, you can go into the properties of that shortcut and specify which profile it uses when it opens. But what if you are navigating in windows file explorer and just double click a drawing to open the software. How does it know which profile to use when it opens?
    2009-11
    5,709
    Default Re: Profile when opening AutoCAD 2022
    Technically it doesn't, just uses previously used (if saved to Registry before fatal crash, etc), which is why most 'best practices' give a finger wag and say not to do that.
    You can however 'push' which version & profile is used via LISP or IT can do so via GPO:
    https://forums.augi.com/showthread.p...=1#post1348620
    If done via LISP, user simply starts CAD first, then subsequent Windows Explorer double clicked DWGs can be opened in that specific version from then on. This is useful if you support projects in multiple versions, or if simply using client-specific profiles, as you can quit that version/project, and launch another version that will then update this setting in Registry so subsequent double clicked DWGs now open in _that_ version, using _that_ profile, etc.
    If done via GPO, it's effectively a one-off, everyone (under that GPO scope) uses the exact same version and profile all the time... So, be sure to use the right tool for the right job.
    HTH
    Computer Specs:
    Turlock, CA
    6,301
    By default, dwg files are set to open with aclauncher.exe. It uses the last used configuration (vertical app and profile) to open dwg files.
    C:> ED WORKING....
  1. Old code not working in AutoCAD 2022
    By cadconcepts in forum AutoLISP
    Last Post: 2021-09-14, 07:45 PM
  2. 2021: 2022: Updated Fabrication COD Script Library (Free download)
    By Darren J. Young in forum FABmep General
    Last Post: 2021-06-24, 06:51 AM
  3. 2021: 2022 issues
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2021-06-23, 12:40 PM
  4. What’s new in Revit 2022
    By amit.sondagar795716 in forum Revit Architecture - General
    Last Post: 2021-05-18, 01:35 PM
  5. 2021: Fix for missing Fabrication Add-ins for Revit 2022
    By Darren J. Young in forum Revit MEP - General
    Last Post: 2021-05-04, 12:56 PM
