Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Xref drawing BASE point Change Random Not by User
  1. #11
    2023-08
    Default Re: Xref drawing BASE point Change Random Not by User
    My firm has had this same issue. It is completely random, and has happened to multiple users in various studios.
    The x-base is inserted into the sheet file and all is good. Notes, dimensions etc are added, and away we go. Then sometimes, without rhyme or reason, you will go into sheet, and the base is missing. Switching to model space shows that they entire base plan has moved. Most recently, it was only about 14". Other times it has been hundreds of feet. Everything checks out in the sheet file, so you go to the x-base and find the issue. Somehow, when you run the base command, the basepoint of the drawing has been changed.
    This has happened to me a few times now. Often I was the only one in the base. I had closed all files the day before, and it was fine. Upon coming in the next day, this had happened. Nothing was changed manually. An Audit shows no issues. changing the base back to 0,0,0 fixes the issue, but it is frustrating when you are trying to get a set of drawings out and have to stop to fix things that should have been set.
    Several people in our firm have researched this, and found no other solutions or possible causes. Currently using AutoCAD 2022 LT, but it was doing it with 2020 LT also. If it is a bug, it has been around for a long time.
  2. #12
    Turlock, CA
    6,302
    I've never had this happen. My first thought would be that someone is doing something that is unexpected. Perhaps editing an xref in-place? I never use in-place editing because it can leave messed up layers.
    C:> ED WORKING....
  3. #13
    2005-06
    in the upper right corner
    3,495
    I've seen a "base" change when e-transmitting files before, it's been a while and I don't know what caused it.
    But I remember that being the action that made it happen, as if a different "base" (insbase) point was assigned when saving out the files.
    That was back in 2008-ish so I don't know if was a bug or something being done wrong.
  4. #14
    2016-05
    17
    Quote Originally Posted by lesley_coleman14 View Post
    Thanks for response -
    No - the xref file is not the problem.
    The CAD file name (x-base) is inserted as a Xref. The x-base file is the drawing that has the BASE point / InsertBase change.
    Example. A floor plan is the x-base.dwg and is Xref in the plan sheet with dimensions in model space. At random times the inserted x-base.dwg "base point" changes. Now the dimensions are not correct because the x-base has a new "base point".
    Check if you are using a third party application or vba or lisp in your work??
  1. 2019: Moving a family (in thid case base cube) to project base point
    By AJ_Error 404 in forum Revit - Platform
    Last Post: 2021-01-27, 08:49 AM
  2. 2021: Change a wall base family to a face base family?
    By Doug in forum Revit Architecture - Families
    Last Post: 2020-12-15, 06:13 PM
  3. 2017: How to add a cogo point along a 3D polyline at a random point
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2018-01-11, 01:42 PM
  4. CV12-4: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-04-17, 04:50 AM
  5. Replies: 3
    Last Post: 2012-05-07, 04:26 PM
