Re: Dim Space
Summary: space from object line
Description: We space our dimensions a certain distance from the object we are dimensioning, and then space each dimension from each other that same distance all based on the scale we are using. We can dimspace the dimensions away from each other, but it would be nice to be able to use dimspace to space the first dimension distance off of the object we are dimensioning. Right now I basically have to draw a line from the object out the distance I want my dimension spaced off of the object. Then I can use dimspace to space any other dimensions I add outside of that one. So it would save a lot of time if I could just throw a bunch of dimensions on the object and then dimspace all of them off of the object line.
Product and Feature: AutoCAD - Dimensions
Submitted By: tsbadgers798401 on 12/08/2021
- You may not post replies
- You may not edit your posts
Forum Rules
