Thread: Clear Mtext formatting
    Wish List Administration
    2011-08
    4,581
    Default Re: Clear Mtext formatting
    Summary: Add the same [Clear All Formatting] option for text available in all Office software.
    Description: In the ribbon for Microsoft Office software there's a [Clear All Formatting] button that easily clear all formatting (such as bold, underline, italics, color, superscript, subscript, and more) from text and returns it to it's default formatting style.
    While AutoCAD's Mtext formatting options are almost the same this clear Mtext formatting option is still missing. Much lisp code has been created to work around this shortcoming but it's time for this to simply be added as an option to the Mtext editor.
    https://support.microsoft.com/en-us/office/clear-all-text-formatting-c094c4da-7f09-4cea-9a8d-c166949c9c80
    Product and Feature: AutoCAD - MText
    Submitted By: Tom Beauford on 12/12/2021
    2005-06
    in the upper right corner
    3,508
    Agreed, this would be nice to have OOTB instead of the need for "StripMtext" lisp or other work-arounds.
    Also have it available through setvars or command-line so scripts or other programming can be run.
    2001-03
    Tallahassee, FL USA
    3,667
    I was wrong AutoCAD already has this.
    In the [Text Editor Ribbon Contextual Tab] Formatting Panel's Clear Formatting (drop-down) there are options to remove character formatting for selected characters, paragraph formatting for a selected paragraph, or all formatting from a selected paragraph.
    https://help.autodesk.com/view/ACD/2...8-A8E06118D3DC
    2005-06
    3,508
    Thanks Tom, that is huge! I didn't know it was there either.
    I found it here in the MTEXT dropdown options, (is that what you meant?) the "Remove Formatting" is grayed out unless there is an over-ridden format in your MTEXT (I just found out).
    2001-03
    Tallahassee, FL USA
    3,667
    Option that works in AutoCAD and most Windows applications is to right-click and select Paste Special → Paste without Character Formatting https://www.makeuseof.com/tag/5-ways...20plain%20text.
    On Windows, while it's not universal, many apps support the shortcut Ctrl + Shift + V to paste without formatting. These include Chrome, Firefox, and Evernote.
    To paste as plain text on a Mac, you can use the somewhat cumbersome shortcut Option + Cmd + Shift + V to paste without formatting. This is a system-wide shortcut, so unlike Windows, it should work everywhere. Technically, this shortcut pastes and matches the formatting, but this has the same effect of removing the original formatting.
