If you look into "Autoload" it may be the answer for you you have a lisp that has all the lisps that you want to run from a shortcut. Its like acad.pgp.
(autoload "COPY0" '("COPY0"))
(autoload "COPYCOMMAND" '("ZZZ"))
(autoload "COVER" '("COVER"))
(autoload "DIMFLIP" '("DIMFLIP"))
(autoload "DRAWXFALL" '("DRAWXFALL"))
The other thing to do is make a manual explaining what all the commands do. I use Word as its easy to copy and paste. Yeah I need to update forgot to change 2005. This was given to all new staff.
LISP programs November 2005
General instructions
These lisp programs are accessed via the following methods from within AutoCAD.
The majority of programs that you will use often have been set-up to load automatically and you need only type a short key sequence to use eg "XP"
If your computer is not set up to load automatically please read the instruction at the back of this guide to enable this method.
How to use
Some programs start straight away and you just follow the prompts. Others will give you a message on the required keyboard entry so program can be repeated again without reloading.
The programs below, names are indicated as well as their shorthand keystroke if available.
