Originally Posted by
Tom Beauford
Here's a quick modification to the linked code from Tom's apt post:
(defun c:-D (/ ) (_AddSubtractDim -1.5))
(defun c:+D (/ ) (_AddSubtractDim 1.5))
(defun _AddSubtractDim (addon / dimss c ddata); = Dimension Text: Add Constant value
(setq
;;; addon (getreal "\nConstant value to add to text of selected Dimension(s): ")
dimss (ssget ":L" '((0 . "DIMENSION")))
c -1
(repeat (sslength dimss)
(setq
ddata (entget (ssname dimss (setq c (1+ c))))
ddata
(subst
(cons 1 (rtos (+ (cdr (assoc 42 ddata)) addon) 2 2)); <-- adjust mode/precision as desired
(assoc 1 ddata)
ddata
(entmod ddata)
If not already done so, it might make sense to have disparate layers for those you're reducing vs those you're increasing. Just to make it easier to select similar & invoke -D or +D, etc.
Cheers
