Results 1 to 10 of 10
Thread: Area Calculation Text - Help Change lisp code
    2015-08
    32
    Default Area Calculation Text - Help Change lisp code
    Hi i am using this code to calculate areas for multy triangles and rectangles. I need a change to this code. I want to replace the talbe with analicic calculation mtext like this :
    E1 = 1/2 x 59.32 x 102.36 = 3035.99 sq.m
    E2 = 1/2 x 16.67 x 85.95 = 716.39 sq.m
    E3 = 73.39 x 97.33 = 7143.04 sq.m
    Total = 3035.99 + 716.39 + 7143.04 = 10895.42 sq.m
    and insert the calculation texts in layout with txt size 2.5
    2015-08
    32
    Default Re: Area Calculation Text - Help Change lisp code
    I am currently working with the area plans, and that last tip was much needed.Can any one help?
    2015-08
    32
    Any option ?
    2002-08
    212
    Without changing the code, but making it simpler? (less assembly of codes coming from right and left)
    2015-08
    32
    Thanks Bruno.Valsecchi
    2015-08
    32
    Hi Bruno. I have a litle problem with the results of the lisp code. Calculate the area using area command and when i do the maths with the export text the area is not the same.
    1) Is it possible to calculate the area using the export dimensions?
    2) After some tests i see when i have triangles that the height of triangle some times is out of the triange. Is possible to use the longest side to calculate the height distanse ?
    2002-08
    212
    Quote Originally Posted by Razor View Post
    Very good point, it's a mistake on my part sorry.
    New lisp code, good use!
    2015-08
    32
    Hi Bruno.. Thaks for the code. But Is it possible to calculate the area using the export dimensions? I check the calculatios with my calculator and i find difference. All the calculations must be done with two decimals because the autocad area use more.
    2002-08
    212
    If this is your wish, then with rounding...
    2015-08
    32
    Thanks you very match Bruno.Valsecchi !!!
  1. Need a help in modification of lisp. Please update the lisp code as required.
    By brahmanandam.thadikonda762224 in forum AutoLISP
    Last Post: 2018-09-20, 04:12 AM
  2. Modification to a lisp (needs to change the lisp code)
    By nanaji130285733687 in forum AutoLISP
    Last Post: 2016-11-21, 04:45 AM
  3. How do I change the area calculation to be rounded to a square foot?
    By bradylady in forum AutoCAD Customization
    Last Post: 2007-11-20, 11:26 PM
  4. Hatched area calculation
    By alhasanatyk in forum AutoCAD General
    Last Post: 2005-03-04, 03:23 PM
  5. Area Calculation Extents Using Room Tag
    By photography67836 in forum Revit Architecture - General
    Last Post: 2004-06-03, 06:31 PM
