Results 1 to 7 of 7
Thread: Structure Top
    Raleigh, NC
    941
    Default Structure Top
    Is there a way to remove smaller rectangle at the top of this structure in the profile view?
    Its a "Slab Top Rectangular Structure" under the Cylindrical Structure Civil 3D catalog.
    Arizona
    2,478
    Default Re: Structure Top
    It would require a trip into to part builder and reducine and or removing that component from the part.
    Or using a user defined block insted of the catalog part
    Raleigh, NC
    941
    Is there a source for an expanded catalog of parts?
    Cairo - no, not Illinois
    5,069
    Well, Florida DOT has a civil3d package, while a lot of it is useless for anything other than FDOT projects - there is a very large catalog of custom drainage structures and pipes.
    Other State DOTs may have their own flavors
    2015-10
    Central New Jersey
    439
    The small rectangle it the structure frame.
    Option 1: Swap this structure for the Rectangular Junction Structure as it has no frame.
    Option 2: Open this part in partbuilder and edit the available values for the frame height to include a selection of 0.0001. (So small it won't be noticeable)
    Raleigh, NC
    941
    Cadtag,
    could you tell me where I could access/download Florida C3D catolog?
    5,069
    https://www.fdot.gov/cadd/downloads/...22caddsoftware
    The install will grad ALL of the FDOT stuff, you'll need to point your pipe catalog to their and build a new parts list
  1. Replies: 0
    Last Post: 2015-08-07, 05:33 PM
  2. Replies: 0
  3. 2014: Tag spot elevation at top of wall - when view cuts wall below top of wall
    By 3dway in forum Revit Platform - Wish List
    Last Post: 2013-07-28, 05:31 PM
  4. Top of Steel or Top of Concrete? Both?
    By scowsert in forum Revit Structure - General
    Last Post: 2007-03-28, 07:09 PM
  5. Round Top vs. Arch Top
    By rsharp in forum Revit Architecture - Families
    Last Post: 2005-09-27, 04:37 PM
