Results 1 to 8 of 8
Thread: Change the cover to a pressure pipe network
    Cairo - no, not Illinois
    5,069
    Default Change the cover to a pressure pipe network
    OK, is there a way for force the cover to a pressure pipe network after it's laid out in plan?
    I had set a reference surface "ROADS" when laying out the pressure pipe, and cover was set to 3' then I went to look at it in profile, and discovered that the inverts elevations are wildly fluctuating.
    Does not appear to be possible to set anything in Panorama for elevation or cover -- I can edit and change the pipe cl elevation in Panorama, but as soon as I click out of that the number reverts. I really hate the thought of manually picking each and every pipe segment in plan and editing the elevation there...
    Ideas?
    Last edited by cadtag; 2022-07-11 at 01:01 PM. Reason: clarified that it's a pressure pipe network
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Change the cover to a pressure pipe network
    Have you tried the ApplyRules command? I've not used it and cannot say for certain that is the fix.
    5,069
    Good thought, but it doesn't apply to pressure pipe networks (Sorry, I was not clear in my post)
    Last edited by cadtag; 2022-07-11 at 02:03 PM. Reason: spelling is hard on miondays
    2002-01
    jUSt Here (a lot)
    9,106
    I haven't used those enough to know what can be changed through automation. May have some options through Dynamo, but probably not.
    5,719
    I don't use Pressure Pipes (yet); have you already tried changing the Offset?
    https://knowledge.autodesk.com/suppo...CCA55-htm.html
    5,069
    That looks helpful, except I did not use the new pipe run feature to build the network, Guess the only way to do do it in Profile Views, adding each pipe to the view and then setting cover there. Lot of clicking....
    5,719
    You could always create a Pipe Run from Pressure Network Parts:
    https://knowledge.autodesk.com/suppo...93B4D-htm.html
    That said, this is all kind of why we still use Pipe Networks for pressurized mains - whole lot of extra work/steps, and styles to manage, when we've already got everything we need for plans production.
    Plus, I've already coded the LispFunction Methods that allow me to use LISP routines to set pipe cover by selection, for Pipe Networks created prior to a proposed Surface being created, or it drastically changes, etc. Normally, we just convert Polylines to Feature Lines, set to Surface grade, raise/lower 3', then create Pipe Network from Feature Lines using them as top of pipe, and merge as needed.
    When new things outperform what we've already got, they're adopted quickly... Just haven't seen that from Pressure Networks (yet).
    Anyway, HTH
    2014-05
    15
    I can't help with editing pressure pipe inverts that have already been drawn. But what I did learn to do was to copy the alignment to a 3dpolyline and project the 3dpolyline to the profile (using object elevation) before creating my pressure network.
    I can do things like set the elevation relative to the surface, and create vertices where I want my valves and fittings to be. I can also set or remove additional vertices in order to model my pipe deflections or set straight sections for pipe casings/crossing. From there, I use the 3dpolyline as a source to create the pressure network from object.
    Editing the 3dpolyline elevation points on the profile is loads faster than editing fittings and pressure pipe sections. When I want to make changes, I just delete the things that go way and add new from another 3dpolyline as needed.
  1. 2018: Pipe Network slows down all dwg files associated with pipe network
    By schmidtzach09771142 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2019-01-14, 09:32 PM
  2. swap part/pipe feature in pressure pipe network
    Last Post: 2015-10-13, 09:05 PM
  3. Pressure Pipe Network Libraries for Civil 3D...?
    By pauldeyo438916 in forum AutoCAD Civil 3D - General
    Last Post: 2015-08-20, 04:33 PM
  4. Data Reference a Portion of a Pipe Network or Pressure Network
    Last Post: 2013-12-19, 04:09 PM
  5. Data Shortcut Pipe Network & Design Pipe Network
    By Openwheeler in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-09-18, 03:47 PM
