Results 1 to 9 of 9
Thread: Cross hair resizing
    2002-11
    11
    Default Cross hair resizing
    I would like to resize the cross hairs in Revit. I remember doing it in Revit.Cant remember how.
    Larry
    2015-08
    199
    Default Re: Cross hair resizing
    What crosshairs? If you are talking about arrowheads, then you find those under manage tab --> additional settings --> annotations --> arrowheads.
    If you are talking about center mark size for radial and diameter dimensions that is found in the type properties of the dimension style.
    For something like a spot elevation that is controlled by a symbol family found in families --> annotation symbols
    2002-11
    11
    So its the cross hairs when you pick a wall to draw from another wall, or just drawing a wall you see the small cross hairs that pop up. I remember there was a way to make them bigger. Its also on the line command as well. Its the small cross hair that shows up.
    Larry
    2010-04
    39
    I believe the cursors' you are taking about are controlled by the operating system not the Revit program
    2015-08
    199
    This is how you change the cursor on windows 10. Right-Click your desktop --> Personalize --> see image for next steps. The cursor icon files are also saved in C:/Windows/Cursors
    Attachment 109024
    2002-11
    11
    Thanks for the Reply. Ive made the cross hairs bigger in Revit before. I just cant remember How. Ive also made them Bigger In Autocad Architecture. Its Really easy in Autocad architecture. Not so much in Revit. So on windows 10 or any other operating system I'm not looking to change the mouse pointer. just in the cad program.
    Larry
    6,397
    Apparently, others are confused about what you mean by "crosshairs" in Revit. Perhaps you could post a screenshot of what you want to change?
    in the upper right corner
    3,505
    I think I know what he means, but I can't even grab a screenshot because it doesn't come through with a print-screen.
    As he mentioned earlier when drawing a line or walls etc, the curser turns into cross-hairs that look like the image I attached (I cartooned what mine looks like)
    I have no idea how to change that, it wasn't in any Options that I could find (expected it in User Interface)
    2002-11
    11
    Thanks for the Reply Ted.
    Yes the curser turns into cross-hairs when you activate walls or Line work. I want it a little bigger.
    I tried to get a screen shot of the cross hair, but it didn't show up for me as well. Your exactly right I tried option settings and couldn't find it there. So I know You can change that cross hair and make it bigger.
  1. Ability to adjust the size of the cross hair cursor.
    Last Post: 2019-06-06, 06:40 PM
  2. Replies: 0
    Last Post: 2011-11-28, 07:21 PM
  3. Aperture Size of Cross Hair
    By Jack Cheong in forum AutoCAD General
    Last Post: 2008-07-31, 03:20 PM
  4. Cross hair freezes when selecting dimensions
    By Fredrik H in forum ACA General
    Last Post: 2007-02-06, 08:20 PM
  5. Whats your cross hair size?
    By H-Angus in forum AutoCAD General
    Last Post: 2006-07-26, 07:49 AM
