Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Creating "smart text" - refer to a detail number & have it change if the detail number changes
  1. #11
    2023-02
    11
    Default Re: Creating "smart text" - refer to a detail number & have it change if the detail number changes
    To achieve the desired behavior you described, you could use the Reference Attribute tool in Revit. This tool allows you to add reference information to your text, and it will automatically update if the referenced element changes.
    Here's how you can use the Reference Attribute tool:
    In the Project Browser, go to the section (Section A) where you want to add the reference text.
    In the Annotation tab, go to the Text panel, and click on the Reference Attribute tool.
    In the Reference Attribute dialog box, select the type of reference you want to add, such as a section reference.
    Select the section (Section B) you want to reference from the dropdown list.
    You can also specify the format for the reference text, such as adding the section number and page number, in the Format field.
    Click OK to insert the reference text into your section.
    To add a leader, you can use the leader tool in the Text panel to draw a line from the reference text to the location of the referenced element.
  2. #12
    100 Club jsr13's Avatar
    Virginia - USA
    134
    I'm afraid that the process you describe isn't correct.
    "In the Annotation tab, go to the Text panel, and click on the Reference Attribute tool."
    There is no Reference Attribute tool where you describe - I have checked versions through 2023. Care to elaborate?
  3. #13
    Turlock, CA
    6,300
    Does this help?
    C:> ED WORKING....
  4. #14
    Virginia - USA
    134
    Does this help?
    Unfortunately, not at all. This thread has to do with adding a reference callout inline with regular text. The link you provided isn't remotely related to the subject matter.
  1. 2017: What does the 10 lb/in^2 refer to in the results diagram and can I change it?
    By tadthurston725387 in forum Robot Structural Analysis
    Last Post: 2018-12-28, 07:31 PM
  2. Replies: 1
    Last Post: 2013-03-16, 11:35 AM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. How to I refer to a detail ?
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-01-16, 10:53 PM
  5. Notes that refer to drawing number on sheet
    By Archman in forum Revit Architecture - General
    Last Post: 2005-07-30, 12:46 AM
Tags for this Thread
