Thread: Draw lines from polyline Edges
    2015-08
    32
    Default Draw lines from polyline Edges
    Hi I am searching for a lisp code to select the polyline and draw the triagles like the attach image
    I dont have it for contours , i want to use it to divide buildings drawings and calculate areas (to write the calculation on the drawing , not to use area command).
    I dont need the dimensions on the lines or the area inside
    2015-08
    32
    Default Re: Draw lines from polyline Edges
    can any one help?
    2002-08
    212
    If the question is simple, the resolution is not at all!
    So you can thank:
    - ElpanovEvgeniy (and ymg for minor correction)
    - Michael Doerr
    for to have sharing their excellent algorithms and me for assembling for your specific request.
    Processes all kinds of 2D polylines (light or heavy) and 3D polylines all closed
    Beware however of bulges for 2D polylines which will not be processed: Acts from vertex to vertex.
  1. Replies: 4
    Last Post: 2014-01-01, 07:58 PM
  2. Add Draw Order/Lines Merge/Lines Overwrite settings to layer properties
    Last Post: 2013-10-25, 01:57 AM
  3. Curved edges shown as straignt edges
    By MARK.PATERSON in forum AMEP Wish List
    Last Post: 2009-03-26, 06:51 PM
  4. Curved edges shown as straignt edges
    By MARK.PATERSON in forum NavisWorks - General
    Last Post: 2008-11-11, 10:27 PM
  5. Jagged edges instead of nice smooth edges on Rendered model
    By strangedj in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-04-25, 11:50 AM
