Thread: Automate entries in drawing title block
    2022-02
    Default Automate entries in drawing title block
    I'm still using ACAD 2007 as it does what I need.
    Can anyone direct me on how to build a title box to automate the inclusion of 1) The file name 2) The layer names used in a drawing 3) The date?
    I have very simple drawings with no more than 12 layer names. Each layer name will tell the operator the material color and in what order they are to be machined.
    White1, White2, Red1, Red2, Red3, etc...
    I engrave text into rocker switch operators (the portion that rocks back and forth). These can be seen at
    2005-06
    in the upper right corner
    3,388
    Default Re: Automate entries in drawing title block
    Quote Originally Posted by autocad799123 View Post
    I'm not sure what is available for 2007, but "Fields" are what you want.
    You can add fields to text or attributes or whatever (rt click while editing text, insert field).
    The "dwgname" and "date" are common fields under "SystemVariable"
    If you want that as part of your title block and you want to list the available layers in it, you will need some object on each layer to list it in a field using the "object" option.
    2001-03
    Tallahassee, FL USA
    3,560
    Fields were added to AutoCAD with the 2005 version so shouldn't be a problem.
    This example section of a lisp which loads every time a drawing is opened sets the file name as the Title in Drawing Properties if it has not been set already.
    (defun C:CustomProps ( / doc SummaryInfo KeyCount KeyValue EngOfRec EOR dcl_id SIZ)
      (setq doc (vla-Get-ActiveDocument (vlax-Get-Acad-Object))
    		SummaryInfo (vla-Get-SummaryInfo doc)
      ); setq
      (if(=(vla-get-Title SummaryInfo) "")(vla-put-Title SummaryInfo (vl-filename-base (getvar "dwgname"))))
    CustomProps
    I reference fields in my title block attributes to automate as much as I can. With attribute editor I can easily add to or replace the field in the attribute.
    Sorry, don't think those visual lisp functions were available with the 2005 version though.
  1. Automate location of object to be inserted into drawing
    By ron.peralta in forum VBA/COM Interop
    Last Post: 2007-06-14, 02:13 PM
  2. Replies: 3
    Last Post: 2007-04-06, 12:05 PM
  3. Automate Drawing Update When Modifing a Presentation
    Last Post: 2006-12-24, 04:57 AM
  4. Convert MDT Title Block to Inventor 10 Title Block
    By julesgordon in forum Inventor - General
    Last Post: 2005-07-18, 08:34 PM
  5. Title Block Entries
    By bmiller.73395 in forum AutoCAD LT - General
    Last Post: 2005-02-08, 07:09 PM
