Thread: Families - Metrique Window
    2022-02
    3
    Post Families - Metrique Window
    Hi everyone i need somme help
    I made a window familie ( metrique familie window) with 3 floors height.
    when i insert the window in the project, i dont see the slice correct in the 1 and 2 floor, only in the 3 floor is correct. The 3D and the vertical slice are corrects. Somme one can help me?
    you can see the image that i upload
    Thank you...
    2013-10
    Default Re: Families - Metrique Window
    check your view range where thr]e cut is happening in relation to the window frame height.
    2002-09
    Madison, WI
    5,687
    Many times I've noticed that the modeled window frame can obstruct the glass lines in section. I'd suggest not displaying the modeled elements in the Left/Right view and use symbolic lines. This way you'll see exactly what you want. You can still lock the symbolic lines to the geometry so it'll still flex as it should.
  1. 2014: Recherche désépérement gabarit de famille métrique et générique métrique
    By archy.design83708281 in forum Revit Architecture - Families
    Last Post: 2015-11-20, 12:45 PM
  2. Tansfert d'un composant générque métrique sol vers composant générique.
    By ph.herrmann in forum Revit Architecture - General
    Last Post: 2012-11-30, 08:21 AM
  3. Modéle générique métrique (adaptatif)
    Last Post: 2012-01-06, 12:53 PM
  4. Cotation - Impérial & Metrique
    By christian.glaude in forum Revit Architecture - General
    Last Post: 2010-10-26, 12:12 AM
  5. Modèle générique métrique (face)
    By keetingraf.183409 in forum Revit Architecture - Families
    Last Post: 2009-09-06, 06:50 AM
