Thread: How to easily change set-up for client standards
    100 Club tomcarver's Avatar
    2015-11
    Tucker, GA
    106
    Question How to easily change set-up for client standards
    Hello, I draw millwork submittals with 2 other guys and we use a system, the same layers, dims, text ..., for all clients. Now we are being asked to conform to the clients drawing standards. How can I easily change the layers, text, dims ... for each client?
    Thanks for your help.
    Tom
    Tallahassee, FL USA
    3,667
    Default Re: How to easily change set-up for client standards
    Have each client furnish templates with the plot styles, layers, dimension styles and text styles.
    They're probably want their own title and other blocks as well.
    Get enough example drawings to know what goes on what layer and hope they use ByLayer for colors, lineweights and linetypes.
    Keep all that and the work you do for them under separate folders for each client.
    Figure how much extra time it will take to produce those drawings and figure it into the cost.
    in the upper right corner
    3,507
    And to add to that, if you have existing cad work that you use over and over, look into using "layer translator" (command: laytrans) where you can map your layers to theirs.
    You can save a .dws and load it again and it remembers what you mapped before.
    Highly recommended for reasons such as yours.
    5,719
    Once you have all of that... don't forget to create a new Application Icon that loads the new client Profile you just created, that's mapped to the client's template, etc.
  1. Replies: 2
    Last Post: 2019-03-15, 03:03 PM
  2. CM31-1: Help! I Have to Use the Client's CAD Standards
    By Autodesk University in forum CAD Management
    Last Post: 2012-11-24, 07:38 PM
  3. MG33-2: Help! I Have to Use a Client's Standards How to Protect Yourself
    Last Post: 2012-11-19, 03:44 PM
  4. how to change finish materials easily?
    By yanyan77 in forum Revit Architecture - General
    Last Post: 2010-03-09, 02:37 PM
  5. Best way to document Client and Company CAD Standards
    By avdesign in forum CAD Standards
    Last Post: 2006-07-12, 08:18 PM
