Thread: Project Manager Palette will not Auto-Hide
    Active Member dervin's Avatar
    2004-07
    Southeastern USA
    85
    Default Project Manager Palette will not Auto-Hide
    Project Manager Palette will not Auto-Hide. I can select the Auto-Hide button to turn off Auto-Hide, then select it again to turn on Auto-hide and it will hide. But once I hover to flyout, it will not Auto-Hide after moving the cursor off the Palette.
    Solved my own problem with restarting Plant 3D. Shouldaknown!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,774
    Default Re: Project Manager Palette will not Auto-Hide
    Thanks for returning with your solution.
    2004-07
    Southeastern USA
    85
    I have figured out what the cause is and I can duplicate it at will. It's happening after I open the Data Manager with the button on the top-right of the Project Manager palette. The button for the Data Manager on the ribbon does not affect the palette. I will just use the ribbon to start Data Manager.
  1. 2014: Problem with Browser/Properties windows not docking
    By konetarchitecture in forum Revit Architecture - General
    Last Post: 2017-05-25, 09:50 AM
  2. Replies: 1
    Last Post: 2014-07-05, 11:24 AM
  3. Tool Palette Auto Hide time, can this be controlled
    By Maverick91 in forum AutoCAD General
    Last Post: 2006-11-09, 10:32 PM
  4. AutoCAD Palette Auto-hide Speed freeware
    By jimmy.bergmark in forum Software
    Last Post: 2006-02-18, 10:14 AM
  5. Tool palette won't auto hide
    By vanderloo5 in forum ACA General
    Last Post: 2005-01-19, 05:54 PM
Tags for this Thread
