Thread: Maintaining as Block Insert but Anonymous Name Prevents Modification via Block Editor
    I could stop if I wanted to CEHill's Avatar
    2006-05
    TN
    327
    Default Maintaining as Block Insert but Anonymous Name Prevents Modification via Block Editor
    Dynamic blocks appeared to solve all related organizational and functional limitations of blocks. The downside appeared quickly thereafter and continues to stupify the everyday CAD user in the form of the anonymous block name.
    Do you know a method or tool or both to employ in modifying the block properties of an anonymous block insert?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Maintaining as Block Insert but Anonymous Name Prevents Modification via Block Editor
    In what form do you wish to modify dynamic blocks? Most properties of a dynamic block can me changed through the Properties palette. If you need it done programmatically, you could make changes using AutoLISP, VBA, or one of the .NET languages.
    2006-05
    TN
    327
    Thanks Opie! I was attempting to change the block definition's layer property from a non-zero layter to layer zero in order to conform to a chosen layer's color property (set as "BYLAYER"0. In my haste, I probably am missing something basic. The Block Editor is not the way ahead here or so it appears.
    I am stuck right now.
    Turlock, CA
    6,420
    Are you trying to do it via code? I'm not sure what you're doing to see anonymous block names. The whole idea of them is that they are hidden from the user interface.
    Note, when you modify properties of a dynamic block, in the background, an anonymous block is created with it's EffectiveName property set to the original block name. So you would need to change the layers of the original block definition in case you insert it again and then update the block insertions too.
    C:> ED WORKING....
    LinkedIn
  1. Anonymous Block Name
    By nathano172904 in forum CAD Management - General
    Last Post: 2010-11-20, 07:22 PM
  2. Replies: 15
    Last Post: 2010-09-23, 01:57 PM
  3. Replies: 14
    Last Post: 2010-03-15, 02:42 PM
  4. Using Backouts Prevents Grip Editing?
    By glynnis.patterson in forum QTO General
    Last Post: 2009-09-09, 04:34 PM
  5. Custom door style prevents recovery
    By gregb in forum ACA General
    Last Post: 2008-07-15, 12:00 AM
