Thread: Excel to Revit via Dynamo Converts Numbers to Text
    100 Club gregb's Avatar
    2003-12
    Phoenix, AZ
    153
    Default Excel to Revit via Dynamo Converts Numbers to Text
    I am trying to write a Dynamo script that will give me the total square footage of Areas grouped by certain parameters which I can then bring back into Revit to use in plumbing fixture calculations. I've managed to get the information written to an Excel file but when I try to import the values from Excel into Revit the square footage gets converted from a number to text. I keep seeing people commenting on how values imported from Excel can be set as numbers but nobody is providing instructions. Could someone please tell me how I can get numbers from my Excel spreadsheet to come into Revit as numbers?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,869
    Default Re: Excel to Revit via Dynamo Converts Numbers to Text
    Are you able to share your Dynamo script with a sample Excel spreadsheet and Revit model?
    2003-12
    Phoenix, AZ
    153
    fixtures required-augi.rvtfixtures required.xlsxAggregate Key_2022-03-29_09-55-58.png
    Hopefully this all attached properly. I'm sure it's not self explanatory so hit me with your questions.
  1. Converts one or more lines of text to mtext
    By Sureshrrai in forum AutoCAD Tips & Tricks
    Last Post: 2008-10-13, 10:23 PM
  2. Replies: 0
    Last Post: 2008-10-13, 10:20 PM
  3. Replies: 16
    Last Post: 2007-05-09, 09:23 PM
  4. AutoLISP program that converts text height
    By aaronic_abacus in forum AutoLISP
    Last Post: 2007-01-09, 12:36 PM
  5. Question for ADT converts [others too, I suppose]
    By shaugh1784 in forum Revit Architecture - General
    Last Post: 2003-12-30, 02:56 PM
