Thread: Laggy pointer vs display performance
    2014-08
    Bend, OR
    7
    Default Laggy pointer vs display performance
    Greetings - this is a new problem in autocad 2022 for me. My previous version was 2018 and this was not a problem. I'm also on a different computer from 2018 to 2022 autocad. The exact issue is if I want a precision pointer I need hardware acceleration turned off. If hardware acceleration is off I literally can not move an xref in my drawing as it tries to redraw it as I try to move it. If I want to be able to move xrefs with no issue I have to turn hardware acceleration on but that causes my pointer/ cursor to lag which is completely untenable. In 2018 I had hardware acceleration on and my pointer did not lag and moving xrefs was easy. What can I do to fix this. Thanks you in advance.
    Cairo - no, not Illinois
    4,988
    Default Re: Laggy pointer vs display performance
    look into toggling the dragmode variable
  1. 2016: Autocad Arch 2016 is Laggy
    By janderson664783 in forum ACA General
    Last Post: 2015-06-24, 06:46 PM
  2. 2010: AutoCad 2010 Laggy...how do I turn off 3d settings?
    By casey.beckmeyer535329 in forum AutoCAD General
    Last Post: 2014-02-04, 06:44 PM
  3. Why is schedule moving and adjusting on sheets so "laggy"?
    Last Post: 2012-09-19, 06:29 PM
  4. Pointer Input - just not fast enough
    By lcamara in forum AutoCAD General
    Last Post: 2005-06-07, 04:24 PM
  5. 2004 Pointer Issues
    By kchurch in forum AutoCAD General
    Last Post: 2004-10-22, 02:30 PM
