Results 1 to 8 of 8
Thread: hide categories in all links but not host
    Member stu1037's Avatar
    2005-03
    ...between bike rides...
    45
    Default hide categories in all links but not host
    I'm a consultant, so I'm Copy/Monitoring the Grids from a Linked model so I can control their visibility better. Same with Room Tags. I have 6 Linked models and they are all doing the same thing.
    Is there a fast way of hiding the Grids in all of the Linked Models, but not in my Host model? I have at least 4 View Templates that will need this. Do I really need to go into each of the 6 Links, change Annotation Categories to Custom, uncheck Grids, and repeat for all 6 links in each of my 4+ View Templates?
    I'm in 2020 atm, and a little surprised I haven't come across this before, but I'm sure it won't be the last time.
    Thank you very much,
    Stu
    2002-09
    Madison, WI
    5,686
    Default Re: hide categories in all links but not host
    Be Happy you only have 6 links to deal with. Typically I've seen this accomplished by making sure all consultants are checking what's on the individual worksets and making sure that only Grids and Levels are on the shared Grids and levels workset. Then you can simply close that workset in the Links manager and you'll never see it.
    Only downfall is if they put something else on that workset that you need to coordinate with. If you need to review the grids (say once ever other week), just open the worksets again via the link manager and go that route.
    Option B for new projects is to start a project, enable workset, add like 10 false links (Links to files with nothing in them) and set up your templates. Then when you start a new project, do a save as a new central and point to the correct links (reload from). This keeps the VG for the Templates and allows you to set it up once.
    Option B - there's a dynamo method that's more of a hack as it won't really adjust the template it adjusts the VG and you can't change it back without removing and reapplying the template.
    That's what I know.
    2017-07
    Virginia Beach, VA
    9
    Unfortunately, you have to. You can create dummy link(s) in your template and then turn off the the grids in VG that way. When it's time to link in a model, just do a 'reload from' and link in your project file(s).
    The other option is what @david_peterson suggested and create a dynamo script.
    2011-09
    The other option is to make the grids in your template have a different type name. For example, if the grid family in my project template is called "Tim's grids", then I can create a view filter that turns off all grids that don't include "Tim" in the type name.
    2016-02
    New York, New York, USA
    5
    Create a view filter to grab all levels and grids not on your levels and grids workset.
    Categories: Grids, Levels
    Filter Rules: Workset, Does not equal your levels and grids workset
    Add the filter to your view template(s), uncheck the visibility check box
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    396
    Quote Originally Posted by tvock531562 View Post
    For grids this is what we do ... although we've had to request our consultants not copy our grid types as that defeats the purpose.
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    617
    This is what we do as well, after all the models have copy/monitored ours I rename the type. It also means I can keep them visible in working views while they're hidden in sheet views. The worksets solution requires me to risk problems if they make a workset mistake and hides them everywhere at once.
    2016-02
    5
    Each party needs to have a unique workset name. Once that is established, it is a great method. Perhaps the easiest to control.
  1. Hide Empty Categories
    By Wish List System in forum ACA Wish List
    Last Post: 2015-02-01, 10:25 AM
  2. Allow family categories to cut other family categories when in the model
    Last Post: 2011-11-27, 11:54 PM
  3. Hide tags... but not ALL of them.
    By matt__w in forum Revit MEP - General
    Last Post: 2009-08-12, 05:34 PM
  4. Host family change to non-host family
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2009-02-24, 04:50 PM
