Thread: Annotate feature line elevations
    2004-06
    Slidell, Louisiana
    928
    Default Annotate feature line elevations
    Is there a way to annotate elevations along a feature line?
    I have a feature line connecting inverts of a ditch and I need to calculate the inverts
    at various points along that ditch, not necessarily at the shots I have, but somewhere in between.
    I don't want to have to insert PI's at those locations, then create a cogo point with the elevation.
    I would like to just pick that point and have the software generate the elevation.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,780
    Default Re: Annotate feature line elevations
    A line or curve label style can annotate the start and/or end z of the feature line. You can insert elevation points on a feature line. These elevation points can be used to have that label style annotate each end.
    2009-11
    5,653
    Can you not just simply add the needed Feature Lines to a Surface and use spot elevation labels (anywhere, not just at PI/EPs)?
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2004-06
    Slidell, Louisiana
    928
    thanks, that's a great idea. I've actually done that before to create a cross section, but forgot about that method.
  1. 2012: Annotate text following path
    By barbara.ivo557941 in forum Revit Architecture - General
    Last Post: 2011-08-25, 01:49 PM
  2. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
  3. Annotate bearing/distance
    By justinxxvii in forum AutoCAD General
    Last Post: 2009-06-02, 09:35 AM
  4. Annotate object data/labeling
    By spy.zefiris in forum AutoCAD Map 3D - General
    Last Post: 2007-04-05, 08:21 PM
  5. Annotate from plot preview type of view
    Last Post: 2006-05-04, 03:19 PM
