Results 1 to 10 of 12
Thread: Rotating value in dynamic block to zero
    2001-01
    257
    Default Rotating value in dynamic block to zero
    Hi All
    I am working with a drawing that has numerous of the same dynamic block. The block is called "UV(2)" and it has to dynamic actions - one to rotate the tag and another to rotate a group attributes that side to one side of the block. The action name that I want to rotate to zero is called "Angle2". Attached is a routine I found on the internet that I have modified but I cannot get to work. I keep getting the following error: "** Error: Automation Error. Invalid input **." I tried putting quotes around the rotation value but that doesn't make a difference. Ideally, I want to rotate the attribute values to zero for all blocks in the drawing. Thatnk you very much.
    Manuel A. Ayala
    (defun c:s2db (/ esb v vval sal salnth count)
    	(vl-load-com)
    	(setq esb nil)
    	(while (= esb nil)
    		(setq esb (entsel))
    		(if (/= (vlax-get-property (vlax-ename->vla-object (car esb)) "effectivename") "UV(2)")
    			(setq esb nil)
    	(setq obj (vlax-ename->vla-object (car esb)))
    	(setq v (vla-getdynamicblockproperties obj))
    	(setq vval (vlax-variant-value v))
    	(setq sal (vlax-safearray->list vval))
    	(setq salnth (length sal))
    	(setq count 0)
    	(while (< count salnth)
    		(if (= (vlax-get-property (nth count sal) "PropertyName") "Angle2")
    			(progn
    				(vlax-put-property (nth count sal) "Value" 0)(princ)
    				(setq count salnth)
    			(setq count (+ count 1))
    	(princ)
    2009-11
    5,719
    Default Re: Rotating value in dynamic block to zero
    Change this one line to get the rotation value change to take effect:
    	(vl-load-com)
    	(setq esb nil)
    	(while (= esb nil)
    		(setq esb (entsel))
    			(setq esb nil)
    	(setq count 0)
    			(progn
    ;;;				(vlax-put-property (nth count sal) "Value" 0)(princ)
    				(vlax-put (nth count sal) "Value" 0.0)
    				(setq count salnth)
    	(princ)
    To process multiple Blocks, simply change the code to allow for multiple selection and iterate that.
    Computer Specs:
    2001-01
    257
    Hi BlackBox
    I changed my code to your suggestion and worked. I needed to evaluate the angle of the original block in order to correctly rotate the attributes. That is all working fine now. My problem now is that I am having trouble with correct way to evaluate an item from a list. Take a look at the line of code with ;; HERE'S THE ISSUE after it. Thanks.
    Manuel
    	(vl-load-com)
            (setq allblklst (ssget "x" (list (cons 0 "INSERT"))))
     (foreach item allblklst
            (setq esb (entget (ssname item (setq i (1+ i))))) ;; HERE'S THE ISSUE
            (setq valchk (cdr (assoc 50 (entget (car esb)))))
            (setq exrot (/ (* valchk 180.0) pi))
            (setq nrotval (* pi (/ (+ (- 360.0 exrot) 90.0) 180.0)))
    	(setq count 0)
    			(progn
    				(vlax-put (nth count sal) "Value" nrotval)
    				(setq count salnth)
    	(princ)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    You need to change your foreach function to a repeat function. You will need to repeat through the length of your selection set. You will want to set a variable for this length.
    You could also use a while function instead of the repeat function.
    You also never assigned a value to i, therefore your math will not work.
    If you are attempting to expand your previous code to allow it to work on a selection set, you may want to determine if the block selected has the correct EffectiveName property before doing all of the other math to save time in processing.
    2001-01
    257
    Hi Opie
    This routine is part of a larger conversion. The drawings that I will be running this routine on will have multiple copy of the same dynamic block. That is why I don't need to find the EffectiveName property for this function. I did change to code according to your suggestions but I am still getting an error message:
    ** Error: bad argument type: consp <Entity name: 2759c9a6030> **. I think it is right after I set the esb variable. Thanks.
    Manuel
    (defun c:s2db (/ allblklst inc esb valchk exrot nrotval v vval sal salnth count)
      (vl-load-com)
      (setq inc 0)
      (repeat (sslength allblklst)
        (setq esb (ssname allblklst inc))
        (setq count 0)
    	(progn
    	  (setq count salnth)
    	(setq count (1+ count))
       (setq inc (1+ inc))
    (princ)
    2009-11
    5,719
    Slight modification of this old post:
    https://forums.augi.com/showthread.p...=1#post1234493
    This is a sub-function & custom command that will make it easier for you to roll out new custom commands, targeting specific dynamic blocks & their properties en-mass.
    (vl-load-com)
    ;;; Custom commands (block-specific):
    ;;; Example:
    ;;; (_SetDynProp "MyBlockName" "DynPropName" DynPropValue)
    (defun c:UV2->0 () (_SetDynProp "UV(2)" "Angle2" 0.0))
    ;;; Sub-function (supports undo):
    (defun _SetDynProp (blockName dynPropName dynPropValue / *error* _GetDynamicBlocks acDoc blocks)
      (defun *error* (msg)
        (if acDoc
          (vla-endundomark acDoc)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
        (princ)
      (defun _GetDynamicBlocks (doc match / oBlocks blockName blocks)
        ;; Example:
        ;; (_GetDynamicBlocks acDoc "*MyBlockName*")
        (if (and (setq oBlocks (vla-get-blocks doc))
                 (setq match (strcase match))
          (foreach space
                   (list (vla-get-modelspace doc) (vla-get-paperspace doc))
            (vlax-for x space
              (if
                (and
                  (= "AcDbBlockReference" (vla-get-objectname x))
                  (wcmatch
                    (strcase (setq blockName (vla-get-effectivename x))
                    match
                  (= :vlax-true
                     (vla-get-isdynamicblock
                       (vla-item oBlocks blockName)
                 (setq blocks (cons x blocks))
        blocks
      (if (setq blocks
                 (_GetDynamicBlocks
                   (setq acDoc (vla-get-activedocument (vlax-get-acad-object))
                   (strcase blockName)
        (progn
          (vla-startundomark acDoc)
          (foreach block blocks
    	(foreach prop (vlax-invoke block 'getdynamicblockproperties)
    	  (if (= (vlax-get prop 'propertyname) dynPropName)
    	    (vlax-put prop 'value dynPropValue)				 ; don't forget to check for allowedvalues
      (*error* nil)
    Computer Specs:
    2022-04
    2
    Place a point parameter. Open properties, set chain action to yes and grips to 0. Set a Move action to include the attribute and associate it with the point parameter. Create the rotation parameter, in the action set include the objects you want to rotate and include also the point parameter, not the attribute
    2001-01
    257
    Thanks. I will try these functions.
    Manuel
    2001-01
    257
    Hi BlackBox
    I am curious if it is possible to change the increment of a dynamic tag via AutoLisp? The block that I am working with has a dynamic angle field which is set to 45 degree increments. When I ran the routine it did not correctly adjust all of the tags that were at an angle that was 0, 90, 180, 270, 360. When I manually edit the block and changed the increment to 1 degree it worked beautifully. Can I edit the increment value with code? Thanks.
    Manuel
    2009-11
    5,719
    Quote Originally Posted by cadconcepts View Post
    Hi BlackBox
    Manuel
    I've just added the 45-degree increment to an angle in one of my own Blocks, manually rotated the Block to 90-degrees, and the code worked here.
    In some quick hunting, I'm not seeing a way to adjust the increment via Visual LISP (perhaps it's possible, not sure).
    Cheers
    Computer Specs:
  1. Replies: 0
    Last Post: 2013-07-26, 11:11 AM
  2. How can I set up Z-coordinate value to be zero and fixed in 2D?
    By thetlin24 in forum CAD Management - General
    Last Post: 2008-10-07, 05:55 PM
  3. Where is my Zero, Zero ?
    By cadclips81126 in forum Revit - Tutorials
    Last Post: 2006-05-15, 08:21 PM
  4. How can I make Project Zero match True Zero?
    By cparsons in forum Revit Architecture - General
    Last Post: 2006-03-23, 02:15 PM
  5. Globally set the elevation so that every object has a value of zero
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2004-08-14, 12:27 PM
