cadconcepts
Hi BlackBox
I am running into a peculiar problem when I insert dynamic blocks into a drawing that already has that block in it with AutoLisp. The first time I run the routine it in an existing drawing, it inserts it, makes changes to the dynamic parameters using your routine (and another similar one) and the routine crashes. When I run it again in the same drawing it works fine. I have tried other routines that insert and manipulate dynamic blocks and the same thing happens. The problem, in short, is the simultaneous insertion and manipulation of the block via code. I can insert dynamic blocks without any issues. This started happening since version 2021. Have you experienced this problem? I've looked for this issue on the internet and I have not found anyone solutions to this issue.
Manuel
