Thread: Line type: Copy/Paste vs Load *.lin file
    2017-09
    6
    Default Line type: Copy/Paste vs Load *.lin file
    General AutoCAD question: We are simply wanting to add line types to a general template. Is there any difference to loading a *.lin file vs simply copying and pasting lines from another file? I don't believe there is a difference, and the question arose because I was asked to load a file that is chock full of bad definitions and thus won't load. We don't need to create new line types, just have them available in a general template. Thank you in advance.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Line type: Copy/Paste vs Load *.lin file
    The bad definitions could simply be the text style is not loaded in the current drawing. You'll need to inspect the definitions to determine what text style it is requesting.
    Unless you are certain the lines from other drawings match the linetype definitions, then there is no difference from loading them from the definition file or copying them from another drawing.
    2017-09
    6
    Thank you!
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Rather than copying and pasting lines from another file I'd recommend using Design Center to drag and drop just the linetypes.
    Of course like Opie said without the Text Styles or required shape files they're not going to display properly.
    If you have a drawing the linetypes work in attach it and any shape files in use and one of us could reply back with a lin file with all the linetype definitions in it.
    With the purge command click [Find Non-Purgeable Items] up top to see which shape files are in use.
    While Text Styles are saved in drawings shape files are referenced and should be shared with drawings.
    2017-09
    6
    Thanks Tom, I'll have to get back on this later, out of the office today. I appreciate your input!
  1. 2021: Can't Copy & Paste. How to clear data from the last Copy/Paste command
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2022-03-30, 12:08 PM
  2. 2015: adding line type to .lin file
    By jwilliams362416 in forum AutoCAD Customization
    Last Post: 2014-07-09, 10:35 PM
  3. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  4. can i overwirte Our acadiso.lin on their acad.lin in Dwg
    By thetlin24 in forum CAD Management - General
    Last Post: 2008-08-19, 03:02 PM
  5. Right-click copy, paste, paste aligned
    Last Post: 2008-07-04, 11:39 AM
